B&O's Adaptive Bass Linearisation and protection for your Beolabs
This post has 51 Replies | 1 Follower
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Oct 15 2013 2:52 PM
And I have pinned it for a month!
Peter
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Thu, Oct 17 2013 11:15 AM
Peter:
Looks like the pin slipped out Peter!
Graham
vikinger
Posts 5,422
vikinger replied on Fri, Oct 18 2013 10:48 AM
vikinger:
Peter:
Graham
EDIT
Just realised that the 'Pinning' only shows if you open a particular and relevant forum. I tend now to just open the active threads page, on which the pinned threads slide into the past unless there has been a recent posting.
Sweden
Posts 357
Silver Member
Martin replied on Fri, Oct 18 2013 2:52 PM
Hi Geoff,
I have followed this thread where you made a comment about the Loudness-function on Beovision 11 and Beoplay V1.
I have a question to you regarding Loudness-function on the Beosystem 3 (or Beovision 7-55):
How much does the Loudness-function (Swithed "ON") boost the bass and treble on the Beosystem 3 mark III (or Beovision 7-55 3D)? Is it the same boost as with Beovision 11 (+12db bass/+9db treble), or is it more or less?
I hope you have the possibility to answer me.
Regards
Martin Ström
SWEDEN
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Geoff Martin
Struer, Denmark
Posts 672
Martin:
Hi Martin,
The simplest answer is "I don't know".
However, the answer is actually more complicated than this, since the auto-loudness function on the BeoSystem 3 also has different turnover frequencies on its filters, and the actual gain applied to those filters at any given volume step will be different. So, a direct comparison of the maximum boost, applied by the systems at the lowest volume settings is only a very small part of the picture.
I'm curious as to why you ask. . .
Cheers
-geoff
Sweden
Posts 357
Silver Member
Martin replied on Mon, Oct 21 2013 1:58 PM
Hi Geoff,
Thank you for Your answer. The reason I ask, is if it is "bad" for the sound-picture if the Loudness is set to "on". The speakers have their own calibration-system, and maybe all "tweaks" should be set to zero to get the most correct sound-balance from the speakers.
Regards
Martin Ström
SWEDEN
Geoff Martin
Struer, Denmark
Posts 672
Martin:
Hi Geoff,
Hi Martin,
It may sound glib - but my honest recommendation is to set the Loudness to whatever you like better. Personally, I leave Loudness set to ON on any device unless I can hear it working too much at low volume settings. If you can hear the Loudness working, then it isn't working properly.
Cheers
-geoff
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sun, Nov 3 2013 12:06 PM
As I can remember loudness was "invented" to compensate the human ear, which is less sensitive for low/high freqencies at lower volumes.
So, a correct loudness function depends on the level of the volume control.
Millemissen
Flensborg, Denmark
Posts 14,680
and on the ear and the room and the recording...
Beobuddy
Posts 3,972
You can't design (loudness) filters based on the infuences of room reflections and or mixed recordings with personal and/or commercial infuences.
Room reflections are only corrected as done with the Beolab 5 internal DSP.
The first function of loudness is to compensate characteristic of sensitivity of the human ear.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Nov 3 2013 3:16 PM
Beobuddy:
Yup, only to compensate for the Fletcher Munsen curves.
Jeff
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Nov 23 2013 10:16 PM
Jeff:
Beobuddy:
Which is why it was called "physiological" filter in many implementations...
Anybody know how the "bass extension" function in Beolab 3000/5000/4500 panel speaker works? I suppose it predates the ABL concept as the service manual doesn't call it such. As I had to do some repairs to my 5000s, I studied the schematic and block diagrams. It has a 4-bit / 16 level control circuit for (apparently) the bass level, directly driven by the microprocessor. What puzzles me is that I can't find any input for the control loop - all the feedback from the output comes in the form of binary "turn the whole bloody amp off now!".
--mika
Page 2 of 2 (52 items) < Previous 1 2 | RSS
