Hi folks,
i just got my first BS3200 for my collection.
never had this one.
unfortunately it doesn’t work.
cd runs, radio runs, even the hdd powers up and I can control through the beo 4 and the panel directly.
Sounds good, doesn’t it? but there is the proble - no sound at all, independent from the input source.
speakers power up, but no tone at all.
and: the headphones are also dead.
i pressed several times the mute button. Dontzknjw, if there should be a click. There isn’t one.
it showed the change of the mute in the display. But no change.
hopefully, there is something I could fix. Any idea?
best regards
69er
Update:
i ran testmodus 27.
there were several errors, but after clearing only one remained:
1 IIC 136 Sound Processor
which part is that? Is it the same as in an Ouvertüre? I have one, which could give parts
All the best
Anybody here with knowledge about the CPU board?
I would like to keep this unit and not send it back.
Best regards
Hallo,das IC ist ein TDA 7318 SMD.Kann aber auch das Eingangs IC2 defekt sein.Oder die Mute Transistoren TR65 und TR68.Oder die Spannungsversorgung +- 7,5 Volt fehlen.Wird das IC4 warm bis heiß?#(Korrektur) Das ist das IC auch für die Lautstärkeregelung. Die Große Platine PCB 12 ist identisch mit der Overture.
VG
My B&O is B&O.
Hallo Comeobert,
vielen Dank für die Tipps - das hilft mir schon etwas weiter.
Das heißt, wen ich die PCB2 komplett tausche, dann ginge es?
Grüße
Hallo,
da es identische Einheiten sind, ja.
Hallo Comeonbert,
ich merke gerade, Du schreibst von mehreren boards, oder?
Das IC, welches Du beschreibst ist der Soundprocessor (1 IIC 136)?
Die TR65 und 68 sind auf dem preamp board (12).
Wo ist der IC2 untergebracht?
Viele Grüße
I had a similar problem with my BS3000. In my case, it turned out that the lithium backup battery had leaked onto the PCB and etched some traces under the battery. I swapped out that PCB and replaced the battery and the unit now works fine. Might be worth examining the battery and PCB to see if there's any evidence of leakage?
Bill
Guten Morgen, die Bauteile sind alle auf der PCB12, nicht PCB2, sorry.
Das IC was ich meine ist IC4.CD4052 sowie CD4094 könnten auch defekt sein.
Zuerst aber sollten alle Versorgungsspannungen kontrolliert werden!Fehlt eine, dann kann auch eine einwandfreie Funktion nicht gewährleistet sein.
Ich bin zu doof um die TR65 und TR68 zu finden. Tausch der Platine mit beosound Ouvertüre oder 2300 geht leider nicht. Sind unterschiedliche.
könnte mir jemand die bs 3200 reparieren?
bin überfordert
gruesse
die PCB12 sind von der Overture und der Beosound 3000/3200 identisch. Es gab zwar eine Serie, da hatte Bang & Olufsen die Bauteile für das Tape auf den Systemen 3000/3200 eingespart.
Die Grundplatine einer 2300er passt nicht.Ist die erwähnte Overture doch eventuell eine 2500er?Zahlentasten links oder in der Mitte?
Sind die Betriebsspannungen alle da?Ohne das zu wissen ist ein ungezielter Tausch von Bauteilen nicht zielführend.
Ich muss mal schauen, welche Ouverturen ich habe (ich muss zugeben, ich nenne die alle so - unabhängig von der Nummer).
Wo messe ich denn die Betriebsspannungen auf der PCB12? Und warum finde ich die Transistoren nicht?
Hallo,es sind kleine SMD Transistoren, meist unzugänglich.Die Versorgungsspannungen +-7,5 Volt sind am besten direkt am TDA 7318 Soundprozessor zu messen.
Liegt ein Service Manual vor?Dort sind die Punkte am IC beschrieben.Aber immer aufpassen, und nicht mit der Messspitze abrutschen und einen weiteren Schaden durch Kurzschluss verursachen.
Wichtig, gegen Masse messen.
Die Overture ist nicht gleich mit einer 2500er!
Das Service Manual der 3200 ist bei B&O leider nicht so ergiebig, wie das der 3000er.
Ich hab die online version von beiden.
Hier das Bild vom TDA - wo kann ich die 7,5 V messen?
Ah, am PIN 2 ?
ja, dort sollten ca. 7,5 = anliegen.
Bin noch nicht zum Messen gekommen, aber jetzt hab ich zumindest mal die 2 Transistoren gefunden (laut Schaltplan).
Auf der PCB Zeichnung des BS3000 (seite 27) ist der TR68 gar nicht beschriftet - deshalb hab ich mir den Wolf gesucht. Er ist unter dem IC8.
Der 65er ist auf der andern Seite.
Aber ich messe erstmal die Spannungen heute Abend.
So, habe eben im standby Modus 0,99v und bei laufender Cd 7,43v gemessen.
das sollte ja in Ordnung sein, oder?
Hab eine pcb 12 aus der Ouvertüre (2631) eingebaut.
die 3200 funktioniert damit
comeonbert lag also richtig 👍
jetzt gilt es den Fehler auf der pcb12 zu finden
ic4 zeigt 7,43v an Beinchen 2
tr65 und 68 zeigen 0,6v und die eine Richtung und vom andren Beinchen 0,8v in die andere.
gehört das so?
sussedem sehen r83 und r84 und c30 etwas angekokelt aus. Sehr hichohmig (leider keine spec gefunden).
bikder lade ich morgen hoch
bitte am IC1 die Beinchen 11 und 12 je messen.
Einmal mit und ohne Mute, ändert sich hier die Spannung?
Bei C30, R84 und R85 würde ich eine Überspannung über AUX vermuten.
R83 mit 2K2 ist in der Kette für die Quellenumschaltung rechts am IC 4.Wie ist der Wert vom R92?
Ja, das sieht nach Überspannung aus. Aber das ist ja ein Eingang (der jetzt wahrscheinlich nicht mehr funktioniert - kann es aufgrund fehelendem output ja im Moment nicht testen :-))
Siehe Bild
Widerstände und Spannungen messe ich noch - hab jetzt die Platine in der Ouverture drin.
Was bedeutet 2k2?
Viele Grüße und Danke für den Support!!!!
2200 OhmOder 2,2 Kilo OhmOder 2K2
Das ist definitiv durch eine Überspannung entstanden!
Ich hab jetzt noch nicht gemessen, aber ne Frage vorweg.
Wie bekommt man denn eine Überspannung an den Aux Anschluss?
R83 und R92 haben beide 2,2kohm
Pin 11&12 sind 0v
mit und ohne mute
Dann ist das IC defekt.
0 V zieht auf Masse, also Dauer Mute.
Einfach den Verkäufer fragen, was er am AUX angeschlossen hat.
Kann ich das IC aus einem ansonsten defekten bc2300 ausloeten und tauschen ?
Guten Morgen,das würde ich nicht machen, ginge aber schon.Ob man das aber sauber und intakt herausbekommt ist fraglich.
SMD ICs auslöten ist mit ungeeignetem Werkzeug immer riskant.Ich verwende immer neue Bauteile.
Das heißt, ich könnte einen neuen TDA 7318 SMD kaufen und einloeten.
dann noch die Komponenten am aux Eingang tauschen
wäre das erfolgversprechend?
muss keine software irgendwo drauf?
Wenn ich einen neuen TDA 7318 SMD einloete und die drei durchgebrannten Bauteile beim aux- ist das erfolgversprechend?
Hallo,ich würde anders anfangen und zuerst das IC1 tauschen, welches mit oder ohne Mute keine Änderung am Pin 11 des ICs ausgibt.
IC1 MC4094.
Auch kann man am IC2 Pin 3 und 13 zumindest über einen Widerstand und Kopfhörer testen, ob die eigentliche Quellenumschaltung funktioniert und ein Ton kommt.Danach weitere Messungen zum IC4 am Ausgang.Aber wer gerne tauschen möchte, nur zu.VG
