Hi, I have recently brought a beogram cdx cd player its mint condition and has been working fine until a few weeks ago. When you load a disc it don't spin up, you load the disc and it moves like a centimeter and stops and on the screen it displays somthing like a question mark. However some times you put a disc in and it works with no problem straight away. its really starting to annoy now Ive tried everything different amps, different cds even a laser cleaning disc but doubt that would do anything because the way the laser shines though the little rising platter thing.
Any help or idea would be appreciated
Lewis
Could it be something as simple as you not loading the CD correctly? If you get the CD to slip down in the holder then you will get the same symptoms of the question mark that you are describing. One of the quirks of the CDX is the loading tray and its ability to sometimes let go of a CD. As you can get it to work sometimes then I have a suspicion that if you double check the CD is sited properly each time the problem will be solved.
Hi, Thanks for your message I have had a go with what you suggested and its still the same now its trying to spin like 1 whole turn of the disc then it stops with the ? sign on the screen. Not quite sure whats going on could it be possible the lock in screws have something to do with the problem ?
Thanks,
The way you describe it, it is probably some electronics problem. Those models had some issues with bad solderings. Or maybe it's some worn out components. It IS rather old - so no wonder if some components need to be replaced.
Sorry to have to tell you those are the symptoms of the classic soldered joint problems but they can also indicate bigger troubles. My CDX had soldered joints repaired which fixed this problem but when it emerged again the service engineer said it needed a new laser board. It was pretty old by then and he said parts were not easy to locate so I sold it to him for spares and bought a Beocenter.
Probably worth dropping it in to a B&O engineer just in case its the soldering problem but I think most will have already had this fixed.
The lasers are bullet proof - the solder joints anything but! Common problem and fixable - worth it as well as this is a very sweet CD player - I compared it with some £1000 new ones a couple of years ago and preferred the CDX.
Peter
I acquired a month ago a beogram cd x that was only powering up: only a question mark, no spinning at all of the cd... Dillen, on this forum, gave me a good direction to look at... then I found a schematic somewhere that Peter gave on a earlier post... I also found this french page on the philip cd 104 (the problems, and pcbs are identical to the cd x..)
http://www.audiovintage.fr/?p=894
and here's the old post:
http://archivedarchivedforum2.beoworld.org/forums/p/28100/220727.aspx
Today I bought a soldering Iron, I've studied carefully for weeks the service manual... I NEVER touched a soldering iron before....
This image is taken from the said french site. It's the servo PCB (no 4) of the philip 104: I only desoldered and resoldered (with a wire passing through the pcb) the two griplets shown with a red arrow. I reassembled all the machine (I did not want to touch to the griplets on the other pcbs... I was sure that, anyways, that would't work and I didn't want to break anything since i'm not experienced at all in soldering...Guess what??? that CD player is like new! I've enjoyed the sound of it all the evening! I can't see any problem with that machine whatsoever...and it what made in 1986! (Ok I was disapointed since I thought that my machine was trimmed with rosewood... I just found out that it was only a vulgar plastic laminate imitating the said wood (I wonder when B&O stopped doing their real wood trimming...)
Anyway it's worth repairing.. If I can do it, anybody can do it... thanks to Peter, Dillen and Kikook! (Now I'll have to tackle that beomaster 8000)
... I also suggest that article by Mike Leach about the philip cd 104 found on tvcaudio. It's a good complement to the beogram cdx...
http://tvcaudio.com/tvc/Philips/documentation/servicing%20the%20Philips%20CD104%20CD%20Player.pdf
Great job Lewis!
Exactly what my own CDX needed too, almost three years ago! It's been working fine ever since.
Now that you've done that you will irresistibly feel like buying and fixing other B&O stuff... Beware, there is no turning back!
Jacques
hamacbleu:(Ok I was disapointed since I thought that my machine was trimmed with rosewood... I just found out that it was only a vulgar plastic laminate imitating the said wood (I wonder when B&O stopped doing their real wood trimming...)
Are you talking about the CD X? Wood trim??? I've never seen that on a CD X
Could you post a picture of your CD X ?
Simili "rosewood" plastic trim. This could peeled off like scotch tape. This is when the eighties went cheap. Altough it does fit with the rest of my equipment...
That "wood trim" is not original.Stuck on by a previous owner, I should think.
Well done on the repair.
Hello Hamacbleu,
Thank you so much for the tips on repairing my Beogram CDX I've own since '86. It stop working in around '98 and haven't used since now. I used my soldering iron on all the griplets with a little silver solder and I couldn't believe it. Thanks so much.
Gary Legge
smokinglegges: Hello Hamacbleu, Thank you so much for the tips on repairing my Beogram CDX I've own since '86. It stop working in around '98 and haven't used since now. I used my soldering iron on all the griplets with a little silver solder and I couldn't believe it. Thanks so much. Gary Legge
Hi Gary,
Congrats on your repair. And thanks bringing me back those nice memories of my 1st successful B&O repair. Mine still plays flawlessly after 4 years, thanks to the resources and supportive people of this forum. The CDX is the most beautiful CD player ever. Hope yours will also bring you years of nice music.
Guillaume
There's a nice article by Tim about the CDX in the November issue of Hifi News & RR. Enjoy!
Heelo,
I have the same problem with a cd-x I recently bought.
So I started to resolder all the connection but it still won't work. Measured connections and they are all good. So far my knowledge off electronic reaches so i am out of options.
Any other ideas?
A CDX is a wonderful cd player from B&O and they do come with a need for service due to age at some point in their lives.
Mine was a basket case with a broken left hinge but thanks to this forum and Dillen it got saved and most likely still works and plays beautifully today.
I agree with Chartz is that could be a lot of different small things causing faults and it is down to the induvidual CDX but most of the time once trouble starts thats when the need for service is called for.
