Beosound 9000 software chip update
This post has 13 Replies | 1 Follower
StKong
Copenhagen
Posts 320
StKong Posted: Wed, Feb 8 2017 10:52 AM
I own a MK2 and I'm looking into the necessity of upgrading the software to allow for N.MUSIC and N.RADIO-functionality as the BS9000 will be part of a larger setup involving Multiroom.
On the archived forum I found a link to a now gone manual on chip replacement, made by Keith.
 Would anyone know if this info is still available online? The link is broken.
Furthermore, is it advantageous and worth the hassle to add the extra source functionality for the sake of the Multiroom setup, or should I just let it be as is? I'm thinking in terms of mapping sources and buttons via the BLC.
Your opinion is appreciated.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Feb 8 2017 11:32 AM
StKong:
let it be..................
in a NL multiroom system it isn't necessary to have the capability of the ML NRadio/NMusic sources. Note: you do not have extra sources - NMusic=ATape2 and NRadio=Phono.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Feb 8 2017 11:39 AM
Is this the link you were referring to in your first post? https://www.beoworld.org/faq_view.asp?id=75
AFAIK, there's more to N.MUSIC and N.RADIO than just selecting the source - it never worked with my BC9500 using ATAPE2 or PHONO!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Feb 8 2017 11:55 AM
Guy:
"true" in a ML system
Guy:
Because the BC9500 had physical IN for A.Tape2 and Phone, so the processor of the BC9500 would open this port and not to the ML system. B&o never claimed it would work with the BC9500 (only on the BS4, BS9000, BS3000, .....; )
Ralf
Hamburg Germany
Posts 189
Ralf replied on Wed, Feb 8 2017 11:56 AM
I ordered the chipupgrade from my dealer.
It costs 100 Euros including shipping.
It comes with minor instructions, the change is really simple.
It upgrades the software to 2.2x.
Now N.MUSIC and N.RADIO are shown in the display instead of PHONO and A.TAPE, but keep in mind it does not add any new A.OPTIONS (5,6) which could be esssential for  your multiroomsetup.
Ralf
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Feb 8 2017 12:12 PM
Carolpa:
Yes, I know!  I was (badly) trying to make the point that B&O also never claimed it would work on BS9000 Mk1!!
Anyway, to the OP - this may be useful: http://archivedforum2.beoworld.org/media/p/1650.aspx
StKong
Copenhagen
Posts 320
StKong replied on Wed, Feb 8 2017 12:19 PM
Guy:
Thanks, Guy. Sadly, no that is not the link. The link is supposed to be a step-by-step guide to chip replacement. Since it is from the archivedforum, the link longer works.
StKong
Copenhagen
Posts 320
Ralf:
Ralf
Are options 5 or 6 crucial to getting it to work with an NL/ML converter?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
The link being referred to went to our very old server which is no longer in service.
However, I have moved the instructions to the current forum server HERE
Regards Keith....
StKong
Copenhagen
Posts 320
StKong replied on Wed, Feb 8 2017 2:19 PM
Keith Saunders:
Regards Keith....
Thank you very much, Keith!!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Feb 8 2017 7:21 PM
StKong:
NO
depending how the BS9000 is connected, option 0,1,2 will do
StKong
Copenhagen
Posts 320
StKong replied on Wed, Feb 8 2017 7:52 PM
Carolpa:
NO
Good, good, CarolpaCool ! Phew.
I was bewildered for a little while.
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 1:11 PM
Wow I just saw the instructions in the link by Keith.
I'm not capable of carrying out such a procedure.
I'm quite glad I found a Mk3...
Regards
Kiran
Born in NL; I ride ML
StKong
Copenhagen
Posts 320
StKong replied on Sat, Feb 11 2017 9:09 AM
Kiran:
I agree, I think the money is well spent on a technician. I can have a drink or three comfortably with calm
conscience in the meantime.
Page 1 of 1 (14 items) | RSS
