Soft-touch laquer deteriorating
Dave
Posts 128
Dave Posted: Sat, May 12 2012 6:47 AM
Hey all,
I've just wiped down my BC2 socket after owning it for just over 2 years (just out of warranty - perfect), the surface seems to have deteriorated! I was only using a damp cloth! It feels sticky... the lacquer seems to have become like the glue residue you'd find left over after removing a sticker.
It's been sitting where it is (out of the sunlight) for about a year, last time i checked it, it was fine, spotless.
What on earth has happened > has this happened to anyone else? I don't remember using any cleaning solution on it in the past either...
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, May 12 2012 12:28 PM
They can feel like then when they are damp or freshly cleaned.  Give it a few hours to dry and it'll be back to its old self.
Lee
Smile
Dave
Posts 128
Dave replied on Sat, May 12 2012 3:52 PM
Hey Lee!
Unfortunately this isn't the case, the socket unit has areas where the soft touch has worn away and a large amount of the surface area is soft and sticky - like glue residue. The soft touch has actually broken down, it's a good thing that the socket unit is a hide away, but it is a shame that it hasn't lasted me any longer then two years... I wonder what has caused it to break down, because the only thing it has been exposed to is air, and a damp kitchen cloth
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Sat, May 12 2012 3:57 PM
Not heard of that happening before on any of the soft touch items, most oddUnsure
Jonnie
Page 1 of 1 (4 items) | RSS
