Hi :)
From my BS Century want to mount connector for line out.want to connect up active woofer or amplifier.I have tried to carry out signal from the headphone jack and the signal is distorted.Please advise if someone allready done that ?Thanks for all opinions.
Nobody done it ?
Iti will be nice to add some active woofer to it :)
I don't have a century and haven't tried.
However, you may well be able to use the DIN aux socket at the back. The set-up manual says that this is an AUX input only, however if you look at the circuit diagrams, then PINs 1 and 4 appear to be AUX out at line level. All these manuals are available on site to silver and gold members.
Hope this helps!
I would buy something like this, so you can use both an AUX input and the line output (if it works) at the same time: https://www.amazon.co.uk/Male-Phono-Plugs-Audio-Cable/dp/B008N29OSG/ref=pd_cp_107_2?_encoding=UTF8&psc=1&refRID=5VTF851WZYEJ2V84FKSW
