What non B&O AV Reciever or AV Processor are people using or recommend
This post has 9 Replies | 1 Follower
Boycey
Posts 13
Boycey Posted: Thu, Nov 22 2012 11:26 PM
Hi
Want to link my beolab 3 speakers to my Panasonic Tv
Would like to run them through an AV Receiver or Processor.
Since the beolab 3s are active speakers, what do i need or need to look at.
Any recommendations ?? With possibility of adding more speakers in the future.
Help much appreciated, as i'm getting confused  Confused
liviu_o
Posts 157
liviu_o replied on Fri, Nov 23 2012 9:22 AM
Hi!
I personally used a rotel rsx 1057 with very good results. Active speakers must be conected to pre-amp outputs so you basically need a pre-amp or a processor, not necesarilly an amplifier.
First thing is to be sure that the "processor"you buy have pre-amp outputs. Otherwise is not useable.
Second: cables. I used RCA- RCA ( also known as DIN cables) for my BL 6000 and 8000 which have "line in" inputs.
I don't know BL 3 what kind of inputs have: powerlink for sure.....line in ???
If they have only powerlink you need mixed cables: powerlink - DIN.
Suggestion: ask Steve at Sounds Heavenly. He can help you with cables.
Liviu
Paul W
London
Posts 1,810
Paul W replied on Fri, Nov 23 2012 1:06 PM
Hi Boycey,
Have a look at the latest Pioneer AV amps. Exceptional quality. We use them in our concert rooms connected to again, Panasonic LCDs. This room is used for record execs, bands, pop stars to promote our brand of stations. As i'm sure you can imagine, sound and vision quality is paramount with these guys!
Flappo
Posts 850
Flappo replied on Fri, Nov 23 2012 1:33 PM
I've always used Yamaha amp's . Very reliable and solid.
Boycey
Posts 13
Boycey replied on Sat, Nov 24 2012 1:30 PM
Great will take a look at all your suggestions, thanks for your help
Boycey
Posts 13
Boycey replied on Sat, Nov 24 2012 2:38 PM
Anyone using one of these: Pioneer SC -LX56-K
Has a few pre outs which would work with what i need????
Also allows for future upgrades.
What do you think.
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Nov 24 2012 3:03 PM
Using a LX 60 works great!
Check my threads to find out about cabling.
Best regards
Ralf
PS: only limited access so not easy to find a thread or post a link.
Boycey
Posts 13
Boycey replied on Sun, Dec 9 2012 12:19 PM
Bought the SC LX56 from Pioneer.
Monster piece of kit.
The cable workshop, Leics, UK
Posts 2,165
Hi Boycey,
Yes, that is a good choice of receiver! Like Flappo, I now always recommend Yamaha receivers as they are great value (they seem to be good at whatever they make, whether it is a motorbike or a grand piano!), but Pioneer are a very close second place.
As the SC-LX56 has pre-out sockets fitted for all audio channels, you can easily connect stereo Beolab speakers (eg. Beolab 3) to these sockets using special RCA to DIN line cables (I build versions for almost all models of Beolab speakers, including Beolab 3).
Beolab 2 or 11 subwoofers and Beolab 7-x or 10 centre speakers can also be connected if required.  If you need any further help with cabling, please feel free to ask.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Evan
USA
Posts 3,621
Evan replied on Wed, Jan 9 2013 2:35 AM
Never heard the Pioneers personally but I do hear very positive critics about the 'Elite' line of gear.
Rotel is a very popular choice. I own one and have heard a couple of others. Mine has a very cold, scientific and clinical sort of sound, but not all are like this.
I also like Yamaha very much. Some of the most honest (and I mean that in the sonic capacity) gear around.
Beo4 'til I die!
Page 1 of 1 (10 items) | RSS
