Is it possible to change the connector for the internal speakers of Beomaster 900K?
This post has 1 Reply | 0 Followers
drfresh
CPH DK
Posts 5
drfresh Posted: Sat, Aug 21 2021 9:58 AM
Trying to disconnect the internal speakers from the plug (during some other repair) have somehow wrecked the internal connector, see picture.
The connector seems to be a five pin 180 degree DIN. But I can't see how to change it? It is not fastened by screws as I can see.
Any ideas?
Thanks.
Homersaurus
Posts 28
Well, those look like plastic rivets from a distance,  Possibly metal, so the likely solution in either case is to drill them out using a small eg. 1mm drill until the body of the rivet has been removed.   A DIN chassis socket should be easy to source and then a couple of short bolts should complete the job.
Page 1 of 1 (2 items) | RSS
