Beomaster 1000 - low sound on left channel
Ari Drucker
Norway
Posts 6
Ari Drucker Posted: Fri, Sep 10 2021 12:59 AM
Hello!
I just got a B&O Beomaster 1000 (type 2316) and connected my Beogram 1700 to it, and Beovox S40 speakers. I plugged the Beogram in to Gramophone II (which has the built-in preamp), right channel sounds fantastic, left channel is much weaker - no buzzing, just kinda dim (both in Stereo and Mono mode).
I first thought the built-in preamp was the culprit, but the problem was still there when listening to the radio.
To isolate the issue, I connected the speaker from the left side to the right speaker output, and it sounded great, so the problem is not with the speaker itself (nor with the speaker cable).
The Beomaster has outputs for 2 sets of speakers but the problem persists in both sets.
I also tried to press/release all the buttons and turn all the knobs up and down several times (while power off) to shake off any dust etc.
So my question is, where is most likely the problem and how can it be fixed?
Also, since I intend to only use one set of speakers, is there a component I could take from the right side of Speaker set B, and put it in the left side of Speaker set A, such that I get 2 working channels on speaker set A?
Any help would be much appreciated!
Thanks!
Ari
Page 1 of 1 (1 items) | RSS
