Beolab 3000/4500 Display Cover
This post has 15 Replies | 1 Follower
Kirby Diver
nottingham
Posts 10
Kirby Diver Posted: Sun, May 12 2013 6:00 PM
Does anyone out there have a spare  display cover for Beolab 3000 amp or any idea where i might try to obtain one please.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sun, May 12 2013 7:42 PM
Got one but needs to be polished, or let your local shop make one. Not that difficult...
Brengen & Ophalen
Kirby Diver
nottingham
Posts 10
Hi Leslie,   Your a star.  I have to polish the other one anyway.  How can i contact you to arrange postage and payment.
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, May 13 2013 10:41 AM
Send me a PM by clicking on my name! Will send you a picture first...
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, May 14 2013 9:33 PM
Here you are...
Brengen & Ophalen
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Wed, May 15 2013 8:18 AM
How do you polish the scratches out???
x:________________________
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, May 15 2013 4:49 PM
I didn't. Ask Kirby Diver...
Brengen & Ophalen
Kirby Diver
nottingham
Posts 10
Hi Leslie,  That cover looks fine how much would you like for it . ?
There is a thread called beolab 4500 display scratches in the workbench area. This shows how to remove the scratches from the covers and what to use.
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, May 16 2013 4:04 PM
Check your mail, we've already discussed that.
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Jonathan:
Maybe this would do, never tried it, but intend to
Jonathan
Posts 1,811
Jonathan replied on Fri, May 17 2013 12:38 AM
Søren Mexico:
Jonathan:
I've tried that... it didn't work for me Sad
Søren Mexico
Mexico City
Posts 6,411
Jonathan:
Did you polish by hand or using a buffing machine, or drilling machine with buffing attachment ?
tournedos
Finland
Posts 7,357
tournedos replied on Fri, May 17 2013 7:37 AM
Søren Mexico:
I'm not sure if the Novus products are enough to remove deep scratches. I bought the Micro-Mesh polishing kit for this particular purpose, and hope that some day I'll have a couple of hours to try it.
Meanwhile, I've read the instruction sheet that came with the kit, and the trick seems to be to never use circular motion. You select the first abrasive grade according to the scratches. Then, you polish in straight lines in the same direction until all that remains are the scratches left by that particular grade. If you made swirls, you can't tell. Then, and only then, you move to the next finer grade and change direction by 90°. Take a shortcut here, and the entire operation will be a failure because the finer grade won't go any deeper than the coarser grade just did.
Obviously follow the instructions of the Novus products, if you try them; I don't know how they are supposed to be used.
--mika
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Fri, May 17 2013 8:09 AM
I found this at some point. Don't know who it is, but judging from the pictures it seems to work well.
This is exactly the process Mika was describing.
http://beolover.blogspot.se/2012/09/beolab-4500-speakers-polishing-of.html
/  Johan
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
tournedos:
Søren Mexico:
You'll need more than a couple of hours, in my experience.
It does work.........in time!
Regards Graham
Jonathan
Posts 1,811
Jonathan replied on Sat, May 18 2013 5:41 AM
Maybe I was impatient...
I used circular motions by hand, and now it just looks really scratched!
Page 1 of 1 (16 items) | RSS
