controlling a Samsung projector with BeoSystem 3
This post has 8 Replies | 2 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Sat, May 18 2013 2:37 PM
I have a Samsung SP-A600 projector connect to my BeoSystem 3. I only have the Samsung SP-A800, A900, H700, and H800 loaded in the PUC. I set the BeoSystem 3 to use the Samsung SP-A800 PUC entry and pressing the "cinema" button on the Beo6 turns on the projector perfectly. However, when I turn off the BeoSystem 3, I get a screen from the projector asking me to confirm that I want to turn off the projector. I can't seem to find a button on the B&O remote that enables me to "enter" the confirmation to turn off the projector. Thus, the projector does not turn off. Can anyone provide any guidance here?
Ehlerz
Posts 51
Ehlerz replied on Tue, May 21 2013 9:07 AM
I think this is a fault in the PUC. It seems that the PUC only triggers On/off once, and the projector needs confirmation when turning off. Is it not possible to do a repeat configuration in the Beo6 setup software somewhere?
I have a similar setup (projector and BS3), however without the PUC as i have a JVC projector. I need you to confirm something for me as i am myself looking to beeing able to turn on my projector using my Beo4. Do you have an IR transmitter connectet to the BS3 and set in front of the projector IR in? If yes, i did not think that pressing "Cinema" itself send IR commands?
Can you please elaborate a bit on your setup?
Thanks in advance
/Ehlz
claudiu
copenhagen
Posts 193
claudiu replied on Wed, May 22 2013 10:28 AM
what model of projector JVC  you have?
i know the dealer here in Denmark  have a JVC X3  in their  beoliving room controlled with puc.
Strandvejen 100  2900 Hellerup, Danmark
+45 39 65 45 54
MartinW
Posts 389
MartinW replied on Wed, May 22 2013 11:33 AM
I have the PUC for the JVC X3 and the Sony VW90, 95, 1000 and the Sony VW30/35 if anyone needs them?
hfat
Vienna, Austria
Posts 663
hfat replied on Wed, May 22 2013 1:38 PM
Hi MartinW,
I have a JVC X9 projector. It would be great to have a PUC.
hfat
Ehlerz
Posts 51
Ehlerz replied on Wed, May 22 2013 2:14 PM
Hi Martin
I have a HD-350 and think that might do with the X3 PUC without any problems.
Do you run a setup with JCV projector and B&O yourself?
I ask because i still do not quite know how it Works. I do not care if i can control the projector with my Beo4 besides the fact that the projector turns itself on when i choose "Format 0" on the remote. (cinemamode)
/Ehlz
Scott Needham
Paris, France
Posts 217
I am looking at controlling a JVC X35 or X55 by my BV7-40. Do you know if the X3 codes will work for these more recent projectors as well. Thanks.
- Scott
PapaJustify
Posts 110
There are PUC files for JVC DLA-X35 and X70 exisiting.
Scott Needham
Paris, France
Posts 217
Great !
Can you send them to me, or tell me where to find them. They are not in Keith's official PUC list.  :-(
Thanks !
- Scott
Page 1 of 1 (9 items) | RSS
