For sale: Beolink 7000 RDS with table charger
tamtapir
Örebro, Sweden
Posts 521
tamtapir Posted: Fri, Oct 31 2014 12:26 PM
I have a Beolink 7000 which I don't use. Everything works as it should, not to say very good. Desktop Charger included. If detailed introduction and/or technical details are desired, I recommend a search on the Internet.
It has two minor dents: one lower corner has an injury in the mirror foil and a little plastic tab is broken at the connector on the desktop charger. However, none of the damage affects operation.
Size and weight makes it ideal to send each as any in the world. The item is located in Sweden.
Asked price 220 euros or a good bid.
A short film at YouTube: https://www.youtube.com/watch?v=Ixj0fAI8S0k&feature=youtu.be
And some pictures:
Page 1 of 1 (1 items) | RSS
