Beovision 7-32 settings for no central speaker?
This post has 10 Replies | 2 Followers
RobN
Posts 54
RobN Posted: Thu, Jun 7 2012 8:34 AM
Hi All,
Apologies if this is already elsewhere in the forum but I couldn't find an answer. I'm buying a 7-32 without the central 7.x speaker to replace my ageing Avant, so want to connect it to the front BL8000s & rear BL6000s. I read somewhere but can't fid it again that you need to "fool" the 7-32 into thinking it has a central speaker to make the front & rears work, is this true?
If anyone can help with advice I'd be most grateful.
Best regards,
Rob
KingOfSnake
Posts 162
Hi Rob,
TV - MENU - OPTIONS - SOUND
think it is Speaker Type but should be fairly obvious.
You will lose a heck load of material hooking up with fronts as 8000's and rears as 6000's - you call tell the TV it has got whatever centre speaker you like.
Personally I would think about hooking the 6000's as your centre and your 8000's as fronts before bothering with the rears, might look odd but that is the price of buying the many screen/stand option offerings where the person has sold the centre speaker for to maximise price, which is fair enough
RobN
Posts 54
RobN replied on Thu, Jun 7 2012 12:59 PM
Hi KingOfSnake,
Many thanks. As my current TV (Avant) is in the corner of the room I've always had the central speaker cranked down on the settings and used the four speakers on setting 4, it seems to work well in my cottage living room. I was looking to do the same, but thought I'd read somewhere that the BV7 wouldn't drive front and rear speakers without having central ones first, but I may be mistaken.
Best,
Rob
Pestria
Posts 58
Pestria replied on Fri, Jun 8 2012 7:37 AM
As KoS says the menus are straight forward.
I've done a similar thing recently and am using a pair of Pentas as the centre speaker (but obviously positioned as front speakers) which seems to work quite well.
As ever with speaker choices play around with the options and go with what works best for you.
Let us know what you decide!
aP
Pestria
Posts 58
Pestria replied on Fri, Jun 8 2012 7:41 AM
I should have added that the equivalent in your setup would be to use the 8000s as the centre, don't bother with fronts and use the 6000s as rears.
Pestria
Posts 58
elephant
AU
Posts 8,219
Hi guys, can you take a look at http://archivedforum2.beoworld.org/forums/t/1500.aspx
and see if there is any advice you can give on that setup ?
TIA - Ed
BeoNut since '75
RobN
Posts 54
RobN replied on Fri, Jun 8 2012 8:44 AM
Hi Pestria,
Many thanks, very encouraging. I will be picking the BV7-32 up later today, so plenty of time to experiment over the weekend :-)
Best regards,
Rob
RobN
Posts 54
RobN replied on Fri, Jun 8 2012 8:48 AM
Hi Elephant,
Most helpful, many thanks. I'll be trying all the options this weekend :-)
This forum is fantastic!
Best regards,
Rob
RobN
Posts 54
RobN replied on Fri, Jun 8 2012 4:15 PM
Thanks again but it doesn't seem to work that way.
It appears if I select none for the centre speaker then I cannot select any front or rear options (they become greyed out on the menu). So I put the 8000s as centre speakers and the 6000s as fronts, but the sound is odd no matter which Speaker option (1,2 or 3) I select. I tried to put the 8000s as centre and 6000s as rears but the menu fro rear is greyed out so I can only put the next speakers as fronts!
My ideal (I think) would be to have centre: none, front: 8000, rear: 6000 but the menus won't let me.
Any ideas would be welcome!
Best regards,
Rob
RobN
Posts 54
RobN replied on Fri, Jun 8 2012 9:26 PM
Please ignore last post! With the help of Matt @ LifestyleAV I've got the speakers working without a central speaker. Many thanks Matt!
All you do is spoof the system into thinking it has a central speaker (e.g. Set Central to BeoLab 7.x) then set the Fronts & Backs to the correct speakers and when listening put the Speaker option via the Beo4 to Speaker 4. :-)
Best regards,
Rob
Page 1 of 1 (11 items) | RSS
DigiCert Secured Site Seal
