Hi all,
I'm looking to get the Amazon FireTV and use it with the Avant55. I want the BeoOne remote to control the FireTV. I have downloaded the Amazon FireTV PUC via the TV.
My current PUC1 plug has two IR sensors wires (A/B) so I've allocated sensor B for the FireTV since A is used for my payTV box. Is this correct?
My question is... Since the Amazon FireTV receives signals via bluetooth from it's native remote, how can the BeoOne Remote, which operates via IR actually work?
Of interest, I have tried the Amazon FireTV stick (connected via HDMI and uses bluetooth connectivity) however the Amazon FireTV PUC I downloaded does not appear to be compatible with it. Maybe I connected the PUC incorrectly or maybe it needs another PUC specifically for the FireTV stick??
I am slightly confused since people recommend using Flirc to transfer bluetooth inputs to IR. Is this required at all for the Amazon FireTV and BeoOne Remote? Surely this is not necessary??
https://flirc.tv/product/flirc/
Any info or support would be great
Thankyou
Ok, great thank you.
Yes that is why I think I'll get the Amazon FireTV because it has a USB port where as the Fire Stick I currently have doesn't.
Would you be able to provide a little more info or even a pic?
Did you download the AmazonFireTV PUC onto your BV11?
How did you program the B&O remote? (Beo4 or BeoOne Remote)
Thank you
Thank you, it's very much appreciated.
I'll order the components and pick them up next week.
