Just received stock of the new H7 headphones. They are the same design as the H6 - available in black or natural. Bluetooth, but without ANC - really nice and priced at £329.
They did upgrade bluetooth a bit to 4.1 from the 'older' 4.0. Internally it is different.
I also noticed the Bluetooth update. The H8 page still says bluetooth 4.0. I think Bluetooth 4.0 chips can be upgraded to 4.1 without any hardware changes. H8 seriously need better radio communication so if it can be updated by software then this would be very good (if it even helps). Some people have problems with them, some doesn't. I've noticed that my H8 has been working quite good for a while but in colder weather they seem to work less satisfactory. Perhaps I have more clothes or there is something with the air or humidity. I have no idea. It just is not very stable. I hope H7 is better, and that H8 will get stable. By the way, H7 does not have noice cancellation so the hardware might be much simpler. A bit confusing that it does not have it since the new H3 does. Well.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I'm still hoping for an on-ear (H5) without wireless.
I am really bummed about the H7 not having noise cancelling.
I was going to buy them also due to the bigger earpads. You dont happen to know about any upgrades to the H8. I like them the most as they have a nice color option and are also packed with all the goodies
Fatandre: I am really bummed about the H7 not having noise cancelling. I was going to buy them also due to the bigger earpads. You dont happen to know about any upgrades to the H8. I like them the most as they have a nice color option and are also packed with all the goodies
I have the H6 and they are pretty good at removing noise just by being over-ear and "passive"
L1NO:I'm still hoping for an on-ear (H5) without wireless.
I don't like the buggy bluetooth part - so i rather see one without. Could shave something of the price aswel.
L1NO:I don't like the buggy bluetooth part - so i rather see one without. Could shave something of the price aswel.
ehh, get the H6?
So would you say they are better than the H8?
Just got the H7, first one in Iceland and only black ones that came.
I am in love. So much better than the H8
Fatandre:Just got the H7, first one in Iceland and only black ones that came. I am in love. So much better than the H8
Why not pop into the store and have a dem..?
BeoNut since '75
elephant:How does Bjork sound on them BeoNut since '75
Duels:Congratulations. Please tell us more about why you prefer them to the H8.
elephant: Fatandre: Just got the H7, first one in Iceland and only black ones that came. I am in love. So much better than the H8 How does Bjork sound on them
Björk sounds amazing.
Try though listening to Gus Gus
Would H8 pads fit the H7?
no.
leosgonewild: no.
Gues I will then just have to wait for brown pad for the H7
Fatandre: leosgonewild: no. Gues I will then just have to wait for brown pad for the H7
Leo is right, I tried this today to check for you whilst in was in the Dublin store. They are very similar in fit (both headphones look *almost* identical with the pads removed) but there must be a slight difference in the position of the ridge that the pads lock into when twisted.
riverstyx: Fatandre: leosgonewild: no. Gues I will then just have to wait for brown pad for the H7 Leo is right, I tried this today to check for you whilst in was in the Dublin store. They are very similar in fit (both headphones look *almost* identical with the pads removed) but there must be a slight difference in the position of the ridge that the pads lock into when twisted.
Thx for that. Shame it wont go together, but maybe better since the H7 dont have NC.
I hope BO will come up with brown ones for the H7
Think that would look bonkers
Got my pair today. So far I love them. I used them on my phone and computer through bluetooth. The bluetooth only made a small cut out for no reason when sitting by the computer and once when I walked into another room which is understandable.
Rather big and flashy so I don't plan on using them walking down the street or public transportation.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
Just some notes since I've been using them for 2 days heavily.
Other than the touch controls I love them though.
New color...nice
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Could anyone who owns, or has tried, both the H7 and the H8 say whether or not the H7 is better at cutting out noise than the H8 in non-ANC mode? That is, do the over-ear cups of the H7 do a better job than the on-ear cups of the H8 without ANC? Thanks.
jonnyb: Could anyone who owns, or has tried, both the H7 and the H8 say whether or not the H7 is better at cutting out noise than the H8 in non-ANC mode? That is, do the over-ear cups of the H7 do a better job than the on-ear cups of the H8 without ANC? Thanks.
I have tried both in-store. I would say the over-ear design of the H7 (and the H6 for that matter) definitely cuts out more noise than the H8 when ANC isn't on.
I have H6s and H8s, and the H6s do block more noise than the H8s without ANC. However, if you're on a plane, the H6s (IMHO) don't block enough noise, and the ANC is very good on the H8s. This is how I happen to have both.
http://www.petertyson.co.uk/ebuttonz/ebz_product_pages/bang_and_olufsen_beoplay_h7.shtml
Seems great value £299
I am torn between H7 and H8.
Had to return my first pair of H8 as they had endless dropouts. Now I also see many people have issues with ANC and high-pitched sound.
As I don't care for ANC but only need a solid wireless pair when I walk around town, H7 comes as an option... ...but then some people report they are too big to be worn outside. *sigh*
Btw: anyone has these new Cenere Gray? How is BT behaving?
I bought a pair of the Cenere Grey H7 this week as I am weighing up whether or not to continue with using the H8.
A quick mini-review:
They look beautiful; the grey colouring has an understated and sophisticated appeal
They sound great - quite different from the H8. The sound is flatter than the more bass-heavy H8, but they have a lovely open sound and some of the high frequency detail is better to my ears than the H8.
Bluetooth performance so far is rock-solid with no cut-outs.
They are more comfortable to wear then the H8 simply because they are over-ear. With the H8 I always find myself adjusting the ear cups for optimum fit (which sometimes leads to the high-pitched feedback problem)
I have no problems wearing the H7 walking around outside. Yes, they're big but then everyone has big headphones on these days. Remember when it was all earbuds a few years ago?
I personally miss ANC on them. If B&O release an over-ear headphone with ANC where they've done a better job of isolating the internal ANC mic from the speaker, then I'll be buying yet another pair of headphones!
Thank you very much for the detailed insight - I think I've made my decision then. H7 it is. :)
As for the color, I was thinking of Cenere Gray too - looks classy on all photos. <3
Yep, grey H7 seems the way to go.
They would have been my choice if I wasn't that happy with my blue H6.
Received my pair of H7 Cenere Gray end of last week - happy to report here that there are no dropouts (still it is advisable to carry your phone in the right pocket).
They are comfortable, even if I'm wearing glasses. I mostly use them when I go out for a walk or need to take care of some errands - the grip is solid and just right.
ANC I really do not miss, I listen to my music pretty loudly plus I prefer to be able to hear at least a minimum of "outer world" sounds like cars honking, cyclist ringing etc. And honestly, I barely get any outside sound.
Some comments I've read around were saying the maximum play volume is too low, well I consider myself playing music relatively loudly and I even do not amp it up all the way to the max so...
Sound signature I think I prefer a bit against H8, there is plenty of bass with H7 but I like very much a kind of openness and transparency on midrange and high (you easily recognize it in vocals).
And yes, Cenere Gray color does not grab too much attention and is rather exact opposite design-wise from the flashy Beats and others.
Oh yes - for Apple Watch owners: Music controls in Glances now support Deezer app too, which means if you play your music via BT from Deezer you get full control on Apple Watch for volume, play/pause, next/previous and it does display song name/artist info. Just mentioning as sometimes I find it easier to pause/play on Apple Watch then with H7 touch controls.
