New Beoplay app
This post has 43 Replies | 1 Follower
mr_anders_son
sweden
Posts 1,710
mr_anders_son Posted: Wed, Jan 20 2016 7:03 PM
New Beoplay app at Apple Store!!
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Millemissen
Flensborg, Denmark
Posts 14,680
Only for iPhone - why?
I use my iPad Mini on the go for music with headphones.
Why not make it 'universal'?
mr_anders_son
sweden
Posts 1,710
Pretty cool app. You can select tone mode, volume etc etc
You must update A2 before you can use the app!
Millemissen
Flensborg, Denmark
Posts 14,680
Ok - does it 'only' work with the bluetooth devices - and not with the headphones out?
AnalogPlanet
Vienna, Austria
Posts 678
Hahaha, for a second I thought there will be a similar functionality like a Mood Whell so I wanted to jump through the roof. But nonetheless, ok to get an update.
Not sure I will be using Beoplay app as I anyway need to stream from Deezer app so... ...well, someone is going to like it. :)
Amazone
Netherlands
Posts 187
Amazone replied on Thu, Jan 21 2016 10:41 PM
I updated my black BeoPlay A2 to the latest software version (9.2.7) with the BeoPlay Software Update tool on Windows 10. Then connected to the A2 with the new BeoPlay App.
The app itself does not bring very much in my opinion, but the very good news is that the whole process including updating works flawlessly and more important, you are now able to change the Bluetooth name of your device. So when you have more then one A2, you can now easily see to which A2 you are connecting. Also very convenient for shops I suppose, where I always have difficulty trying to connect to the right device.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
benoit
France
Posts 646
benoit replied on Fri, Jan 22 2016 7:33 AM
Amazone:
Lucky you... With mine the updating process crashed immediately and after it the Beolit 15 refused to start again. No reaction. Dead. Even when plugged to the main, the charging led didn't react. It's back to the shop and I'll have a new one in some days under warranty.
benoit
France
Posts 646
benoit replied on Fri, Jan 22 2016 1:41 PM
I received right now a new replacement from the shop I bought it (not a BO store). I tried to download the update and.... exactly the same happend! DEAD!!!
I think I'm definitely out of B&O world....
Michael
Sweden
Posts 2,578
Michael replied on Fri, Jan 22 2016 2:08 PM
Im curious to why this doesnt work with B&O play headphones. Although, I have to say its awesome to have this for the Beolit 15, I can't wait to try it out. Sometimes I find the BeoLit 15 too bass heavy, its not always a good thing :-).
Michael
Sweden
Posts 2,578
Michael replied on Fri, Jan 22 2016 2:32 PM
benoit:
Perhaps you should use another computer? It sounds like it cuts communication while flashing firmware or that you do something wrong.
davieav
chester UK.
Posts 49
davieav replied on Fri, Jan 22 2016 2:41 PM
i have given up on this
it does not recognise i have an A6 ( playing beautifully as i opened the app )
i turn on the bluetooth as requested , tell the app which product i have and it says .." to set up my A9 ...."
wish i had one !
done this every single time i try
Sal
California, USA
Posts 1,197
Sal replied on Fri, Jan 22 2016 2:52 PM
davieav:
wish i had one !
The A2 worked flawlessly for me, but I'm experiencing the same problem as you Davieiv with my A6. The app needs work. My A6 is on and playing and the BeoPlay app doesn't see it. Just checked, and the SW for the A6 is current. Oh well. It is fine just as it is.
I'm curious why B&O chose to release a separate app, rather than integrating some of the functionality into already existing apps? BeoMusic, BeoRemote, BeoSetup, BeoPlay, I'd really find it refreshing not to have so many separate apps, rather than one single "BeoCentral / BioControl" App which can do what all of these do in one place.
benoit
France
Posts 646
benoit replied on Fri, Jan 22 2016 3:07 PM
Michael:
benoit:
It worked on the same computer with an 'old' Beolit 15 (gold color) but it didn't twice with the new silver one! So I don't do anything wrong. It stucks immediately when I press continue to start the update... and I instantly have the message telling to reconnect and try again.... I wanted 2 Beolit 15 to use as stereo. But I'll give up.
Amazone
Netherlands
Posts 187
Amazone replied on Fri, Jan 22 2016 4:05 PM
Sal:
I agree with this. It is not exactly clear what to use which app for. The Beoplay app seems more or less a Beosetup for Bluetooth devices.
BeoMegaMan
Posts 601
benoit:
Michael:
benoit:
You should just ask your dealer to update it before you leave the shop.
Ah, you know... A little B&O here, a little there
Michael
Sweden
Posts 2,578
Michael replied on Fri, Jan 22 2016 6:39 PM
benoit:
I have just upgraded my H8s and my Beolit 15 (grey model). It worked flawlessly on my Mac.
BeoMegaMan
Posts 601
For the record the app only works with A2 & BeoLit 15 currently. It's designed only for the BT only products. Not products that support Wifi + BT. The idea is that the Wifi products will in most cases be on a network and therefore have access to the portal for updating. Not sure if the BT headphones will get the ability to talk to the app or not. In the app description it tells you what products it's compatible with currently.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Jan 22 2016 6:52 PM
Seems like the update brought battery indication for Beolit 15 over bluetooth as well. But not displayed in the iOS notification center or up by the bluetooth symbol as the H8 does. I hope B&O adds this in future updates so we don't have to look for a red light on the back of beolit 15 :).
Sal
California, USA
Posts 1,197
Sal replied on Fri, Jan 22 2016 9:20 PM
BeoMegaMan:
Thanks for that, it helps. The interesting thing is that if you click + the choices you're given include the A6 and almost all of the BeoPlay line. The home screen, though, does only show outlines for the A2 and Beolit 15.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Jan 25 2016 9:43 AM
Sal:
There is a picture that shows the supported units and that more units will be supported in the future as you say, but perhaps not all firmwares are released yet. B&O sent me an email about the app today so I guess they might have rolled them out now.
elephant
AU
Posts 8,219
elephant replied on Tue, Jan 26 2016 6:19 AM
In its current form for an A2 it seems a case of "Much Ado About ..." vey little
Still it was nice to label the A2 with SWMBO's name; and just was not fussed by the tone control.
BeoNut since '75
mr_anders_son
sweden
Posts 1,710
New Beohome app for ipad
http://www.bang-olufsen.com/en/collection/apps-and-accessories/beohome-design-app
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jan 29 2016 12:25 PM
mr_anders_son:
Nice :)
Will be fun to see what the BL90s will look like in my living room :)
Duels
England
Posts 2,553
Duels replied on Fri, Jan 29 2016 12:49 PM
mr_anders_son:
We're gonna need a separate "flash your B&O" thread to separate real from imagined set-ups!!
mr_anders_son
sweden
Posts 1,710
Its not compatible with my 2 years old ipad!!!!!!
Can not intall it:-(
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jan 29 2016 1:51 PM
Your iPad must be older than that :)
It is supposed to work on an iPad Air (launched October 22, 2013)
mr_anders_son
sweden
Posts 1,710
Hiort:
3 gen and 3 years old!!!
not ok:-(
Millemissen
Flensborg, Denmark
Posts 14,680
mr_anders_son:
Hiort:
not ok:-(
It is 'heavy stuff' that you are moving around - you'll need a powerfull iPad ;-))
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Jan 29 2016 5:51 PM
I tried it. The first impression is that the app starts upside down and doesn't agree to rotate. Oh well, it probably will be easier to use with the camera lens in an upper corner anyway, so I rotate the piePad.
I of course want to try the augmented reality feature at once to see how my future BL90 pair will look in the kitchen. I know it probably would work better with the special marker page, but I don't have a printer at home. Fortunately it appers to be able to use (any?) magazine as a reference, so I place one on the floor and select "magazine". The camera turns on and the app asks me to "center the marker on the screen". Hey, I already told you I don't have one. I can't get the app to register anything. I'll try again at work on Monday.
I didn't try the room planner yet as I don't have any more time right now.
--mika
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Jan 30 2016 4:57 PM
Tried the app last night and added an A9 and a pair of BL90s in my living room Smile
Quite easy.
Wanted to continue today but now the app just says "wait" after adding a product and then seem to hang. Bug och server overload?
SimonS
Posts 9
SimonS replied on Sat, Jan 30 2016 8:29 PM
Hi
If you don't have a Marker/Magazine then you can tap on the 'No' icon and you will be able to place BeoLab 90s. The scale will not be as accurate but hopefully it will give you a good idea what it will look like.
The feedback in your post has been really helpful and by the end of the week amendments in the app will help clarify some of the issues you were having.
- Simon
SimonS
Posts 9
SimonS replied on Sat, Jan 30 2016 8:44 PM
Sadly it doesn't work with the slightly older iPads as there is quite of processing power is needed to deliver a good performance. Looking down the line with future updates we needed to focus on the newer models.
- Simon
SimonS
Posts 9
SimonS replied on Sat, Jan 30 2016 8:47 PM
I glad you had a good initial experience, the developers have noted the issue and are trying to recreate the issue to find the bug. Thanks for the feedback.
- Simon
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Feb 11 2016 11:58 AM
Does anyone know if the app communicates with the DSP in e.g the A2?
When I have adjusted the sound in my A2, using the app, the A2 stays with that sound setting even if the app is not activated next time I play from my iDevice.
jonnyb
Posts 92
jonnyb replied on Thu, Apr 21 2016 11:14 AM
The app has been updated for the A1 and also the H7 and H8.
However, there's still no support for the S3. Is the S3 the forgotten child of the Beoplay speaker range?
jonnyb
Posts 92
jonnyb replied on Thu, Apr 21 2016 1:28 PM
I take it back! There is now updated software for the S3 so it can work with the Beoplay app. I've just updated mine.
Michael
Sweden
Posts 2,578
Michael replied on Thu, Apr 21 2016 1:45 PM
I just updated my H8s´s to the new firmware. They now sound different when switching ANC on and off. They make a "bliblipp" noise in both earphones at once. Before they seemed to enable on one earphone at a time and without the same noise.
The ANC can be enabled and disabled in the BeoPlay companion app as well - but its buggy so turning it off doesn't work, it just enables ANC when it is already enabled, but it states "off".
But the best thing of course is that you now can set the sound profile to your liking. There's been a lot of talk about H8 being too bass heavy (even though I think it changed in an earlier firmware - according to my ears). But now you can pick your favorite sound profile :D.
jonnyb
Posts 92
jonnyb replied on Thu, Apr 21 2016 1:55 PM
It's a very good update. The noise cancellation toggle works fine for me, though.
Michael
Sweden
Posts 2,578
Michael replied on Thu, Apr 21 2016 2:44 PM
jonnyb:
In the App? it works fine with the controls my headphones, but not in the app.
jonnyb
Posts 92
jonnyb replied on Thu, Apr 21 2016 2:49 PM
Yes, it works fine for me in the app.
Page 1 of 2 (44 items) 1 2 Next > | RSS
