Hey everyone, I'm planning to buy a new home theatre set up:
Beovision avant.
Beolab 18.
Beolab 19.
My question is what all comes in the box with these products? Do you have to buy the remote and wall bracket separately for the avant?
Do you have to buy the beolab transmitter 1 separately for the lab 18 and 19? Also do i need to buy the front lamellas in beolab 18 separately by paying extra?
Thanks in advance.
I think the avant comes with the beo 1 remote with the bracket being purchased seprately.
Beoplay A2
Yes you have to buy a wall bracket, but the remote is included.
You do not need a Transmitter as it is build in the Avant.
Yes the lamellas you can choose Wood or plastic where the Wood is much more expensive.
Thanks for your response. What about the beolab wireless transmitter 1? Is that included with the speakers or will I have to buy it separately. Also, I'm planning to get the black composite lamellas and not the wooden ones. Will I still have to buy them separately?
gmittal:Thanks for your response. What about the beolab wireless transmitter 1? Is that included with the speakers or will I have to buy it separately. Also, I'm planning to get the black composite lamellas and not the wooden ones. Will I still have to buy them separately?
