New Home Theatre Set Up
gmittal
Posts 44
gmittal Posted: Sat, Aug 23 2014 6:35 PM
Hey everyone, I'm planning to buy a new home theatre set up:
Beovision avant.
Beolab 18.
Beolab 19.
My question is what all comes in the box with these products? Do you have to buy the remote and wall bracket separately for the avant?
Do you have to buy the beolab transmitter 1 separately for the lab 18 and 19? Also do i need to buy the front lamellas in beolab 18 separately by paying extra?
Thanks in advance.
markiedee
UK
Posts 425
markiedee replied on Sat, Aug 23 2014 6:39 PM
I think the avant comes with the beo 1 remote with the bracket being purchased seprately.
Beoplay A2
Emil Jensen
Denmark
Posts 766
Yes you have to buy a wall bracket, but the remote is included.
You do not need a Transmitter as it is build in the Avant.
Yes the lamellas you can choose Wood or plastic where the Wood is much more expensive.
gmittal
Posts 44
gmittal replied on Sat, Aug 23 2014 7:46 PM
Thanks for your response. What about the beolab wireless transmitter 1? Is that included with the speakers or will I have to buy it separately. Also, I'm planning to get the black composite lamellas and not the wooden ones. Will I still have to buy them separately?
gmittal
Posts 44
rob08
Posts 209
rob08 replied on Sat, Aug 23 2014 8:46 PM
The transmitter is built-in the Avant. The speakers (18 & 19) also have wisa receivers built-in.
Don't know regarding the black lamellas but would guess that the black & white are included in the price.
Also, if you buy all that kit from the same dealer I am sure you'll get some rebate or something like it
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Aug 23 2014 8:56 PM
gmittal:
Beolab 18 with black or white lamellas are much cheaper than with the wooden lamellas.
Page 1 of 1 (7 items) | RSS
