Can I add s45-2 to a Beovox 4600 with s35 speakers?
Michele11
Posts 3
Michele11 Posted: Wed, May 12 2021 4:48 PM
Hello! I’ve just purchased a fab 4600 but having read all of your posts I am craving some s45-2’s! I have 0 tech skills. Do they have the same wire fittings? The 4600 is great and all working except the tape deck volume goes up and down. Any advice on that would be fab๐Ÿ’—
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, May 12 2021 5:02 PM
All B&O passive speakers (since apprx. year 1963) have the standard DIN fittings.
Smart, isn't it?
So yes, you can use either pair.
- Or both.
Michele11
Posts 3
Michele11 replied on Wed, May 12 2021 5:04 PM
Brilliant! Not like Apple then ๐Ÿ˜‚
Dillen
Posts 13,191
Dillen replied on Wed, May 12 2021 5:11 PM
- But your speakers could have captured or separate cables. You can check that.
All Beovox S45-2 have countersunk sockets at the back and therefore needs separate cables, so make sure you also get them (or buy some off Ebay etc.).
Michele11
Posts 3
Michele11 replied on Wed, May 12 2021 7:29 PM
Whaaat? Now I’m confused ๐Ÿคจ๐Ÿ˜‚๐Ÿ’—
Dillen
Posts 13,191
Dillen replied on Wed, May 12 2021 7:52 PM
The question is merely, if your "existing" speakers have cables that unplugs from the speakers or not.
Page 1 of 1 (6 items) | RSS
