Hello! I’ve just purchased a fab 4600 but having read all of your posts I am craving some s45-2’s! I have 0 tech skills. Do they have the same wire fittings? The 4600 is great and all working except the tape deck volume goes up and down. Any advice on that would be fab๐
All B&O passive speakers (since apprx. year 1963) have the standard DIN fittings.Smart, isn't it?
So yes, you can use either pair.- Or both.
Brilliant! Not like Apple then ๐
- But your speakers could have captured or separate cables. You can check that.All Beovox S45-2 have countersunk sockets at the back and therefore needs separate cables, so make sure you also get them (or buy some off Ebay etc.).
Whaaat? Now I’m confused ๐คจ๐๐
The question is merely, if your "existing" speakers have cables that unplugs from the speakers or not.
