Bv10-32
This post has 1 Reply | 2 Followers
kai
Posts 362
kai Posted: Mon, Jun 25 2012 11:45 PM
I have a question about above tv. I was setting for a freind which has sky hd box and oppo DVD player I have them both controlled via puc, but I notice the tv is slow to start up, when it does come on. If I change source from Sky to DVD or vice versa it just seems slow, Is this normal for this set!!
Heribert
Vorarlberg / Austria
Posts 804
Heribert replied on Tue, Jun 26 2012 7:27 AM
Normal start time is around 20-25seconds. A change between sourced is usually not slowed by the TV itself, but the device you´re changing to. Once you press the source button it powers up the connected device which may take a while.
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Page 1 of 1 (2 items) | RSS
