I just wanted to know if others have problems with deezer on their Horizon, mine is writing the page is unavalable.
Have uninstalled and installed the app a few times, no luck
Try installing the Deezer Mobile version, being a different product. You will end up with two Deezer apps, one with a slightly different background colour . That one should work.
Beoaus.
Helle Aus
Cool I will try to find that, did`nt know that you could do that
Well I got home and wanted to try and find the mobile deezer .... I just tried one more time to open the deezer app on the tv and it opened ... weeeee .. I heard music on it for a while, no problems..... then later I turned the tv on again and wanted to hear som more music, but then i got tha same message again, the page is not avalable, but the last time I deezer worked, I did put the deezer page on one of my “my choice” buttons.
if I press that it wants to log on to a bang&olufsen smart tv server. ..... with no luck, it looks like I need to do some registration, could that be my problem?
but when I look in the manuals I cant find anything regarding this .....
Master123456789:Mine on bv11 is also very unstable. Ofen useless, don’t start up. Can I download the app also on bv11?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Inferno82:And why the first deezer won’t work?
Is there anything I can do about it?
cant find a way to install the mobile deezer
Micsv: Is there anything I can do about it? cant find a way to install the mobile deezer
My experience is with the Horizon.
You could try the following.
Goodluck, Beoaus.
