Horizon and Deezer
This post has 11 Replies | 2 Followers
Micsv
Posts 5
Micsv Posted: Sun, Mar 4 2018 6:31 AM
I just wanted to know if others have problems with deezer on their Horizon, mine is writing the page is unavalable.
Have uninstalled and installed the app a few times, no luck
beoaus
Posts 177
beoaus replied on Sun, Mar 4 2018 7:32 AM
Try installing the Deezer Mobile version, being a different product. You will end up with two Deezer apps, one with a slightly different background colour . That one should work.
Beoaus.
Micsv
Posts 5
Micsv replied on Sun, Mar 4 2018 10:29 AM
Helle Aus
Cool I will try to find that, did`nt know that you could do that
Inferno82
Posts 47
Inferno82 replied on Sun, Mar 4 2018 11:53 AM
And why the first deezer won’t work?
Master123456789
Posts 237
Mine on bv11 is also very unstable. Ofen useless, don’t start up. Can I download the app also on bv11?
Micsv
Posts 5
Micsv replied on Sun, Mar 4 2018 5:51 PM
Well I got home and wanted to try and find the mobile deezer .... I just tried one more time to open the deezer app on the tv and it opened ... weeeee .. I heard music on it for a while, no problems..... then later I turned the tv on again and wanted to hear som more music, but then i got tha same message again, the page is not avalable, but the last time I deezer worked, I did put the deezer page on one of my “my choice” buttons.
if I press that it wants to log on to a bang&olufsen smart tv server.  ..... with no luck, it looks like I need to do some registration, could that be my problem?
but when I look in the manuals I cant find anything regarding this .....
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Mar 4 2018 5:51 PM
Master123456789:
Nope, you cannot.
beoaus
Posts 177
beoaus replied on Tue, Mar 6 2018 5:47 AM
Inferno82:
I believe the first Deezer is updated by Deezer to take advantage of the latest Android TV platform. The Horizon is a few Android revisions behind.
Beoaus.
Inferno82
Posts 47
But i have avant ng, and same problem, page not found
Micsv
Posts 5
Micsv replied on Tue, Mar 6 2018 11:59 AM
Is there anything I can do about it?
cant find a way to install the mobile deezer
beoaus
Posts 177
beoaus replied on Mon, Mar 12 2018 11:51 PM
Micsv:
My experience is with the Horizon.
You could try the following.
  1. Refresh Andriod
  2. Uninstall the other version of Deezer
  3. Power off the TV, then let it restart and connect to the B&O Server, so wait 90 mins.
  4. Then try to install the version of Deezer I suggested thru the App Store. Wait 10 mins or so, could be longer.
  5. If Deezer Mobile installs, then you have a choice to try the app or do a power off, then disconnect the power plug.
  6. Try the app, be mindful as you may still have 2 Deezer apps. I found I could not permanently uninstall the other Deezer app.
Goodluck, Beoaus.
Micsv
Posts 5
Micsv replied on Thu, Mar 15 2018 6:25 PM
Hello Beoaus
Thanks for your input, I finally got it with the mobile deezer app.
Now I dont have to replace the tv with an older avant
Page 1 of 1 (12 items) | RSS
