Set up Beovision 11-55, 6000 speakers front and rear, Beolab 2
If I switch the left hand speaker to right channel, I get sound, but not when it's switched to left channel. If I change the front right speaker to left channel, no sound, but working as it should on right channel
To a novice, this sounds serious. Any thoughts?
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
What source are you using?
Internal tuner / external device (connect via ...)?
Is the Balance set to the very right?
Ralf
Hi both
Thanks for prompt reply. Using internal tuner
Sorry I clearly didn't explain myself very well. Sliding the internal speaker switches is exactly what I have done. Right hand channel works, but not left hand - for both left and right speakers. Balance is correct
Fault identified, a replacement cable has been ordered! Phew!
