Front left hand speaker not working
thorne
Posts 315
thorne Posted: Thu, Nov 27 2014 2:15 PM
Set up Beovision 11-55, 6000 speakers front and rear, Beolab 2
If I switch the left hand speaker to right channel, I get sound, but not when it's switched to left channel.  If I change the front right speaker to left channel, no sound, but working as it should on right channel
To a novice, this sounds serious.  Any thoughts?
olvisab
Posts 1,391
olvisab replied on Thu, Nov 27 2014 2:25 PM
Did you check that every speakers is set to the good side (under each speaker select right of left) ?
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Nov 27 2014 2:48 PM
What source are you using?
Internal tuner / external device (connect via ...)?
Is the Balance set to the very right?
Ralf
thorne
Posts 315
thorne replied on Thu, Nov 27 2014 3:19 PM
Hi both
Thanks for prompt reply.  Using internal tuner
Sorry I clearly didn't explain myself very well.  Sliding the internal speaker switches is exactly what I have done.  Right hand channel works, but not left hand - for both left and right speakers.  Balance is correct
thorne
Posts 315
thorne replied on Sun, Nov 30 2014 12:27 AM
Fault identified, a replacement cable has been ordered!  Phew!
Page 1 of 1 (5 items) | RSS
