Beomaster 3000-2 acts up after one hour - feedback noise
ga53n
Hamburg, Germany
Posts 17
ga53n Posted: Fri, Feb 13 2015 10:29 PM
Hi there,
I am quite new here and hope that you can help me with some issue I have with my Beomaster 3000-2 that I have obtained some time ago.
When I  got is up an running I noticed a steady hum from the power supply and ordered some replacement capacitors. While waiting for the parts I noticed that the device emitted a screeching noise after some time in operation (between one and two hours), something sounding like a feedback loop.
The noise is quite loud on both channels and  does not change when I move the volume control. After some 20 seconds it goes away and the unit behaves well for a  while.
I was hoping that it would go away when I replace the capacitors.
Today the parts arrived ant I replaced the capacitors. Unfortunately I had to learn that this did only solve the issue with the hum, but I got the noise coming back.
Does anybody have an idea what is causing this issue and how I cold repair it?
Any ideas are welcome, thanks for your help
G
Page 1 of 1 (1 items) | RSS
