Control of Set Top Box through BeoVision 6
noby39
Posts 13
noby39 Posted: Thu, Feb 26 2015 5:27 PM
I own a BeoVision 6. It is connected to a Sky + set top box. Recently the B&O handheld controller stopped working with the Sky + box, but otherwise works with the Menu, Exit, etc functions on the TV .  I can change channels, etc. on the BeoVision 6 using the Sky handheld controller. I checked that the cable running from the IR-Out on the BeoVision 6 to the Sky + box is connected to the TV but I'm unable to test if there is a signal on that cable.  Any suggestions would be welcomed.
lawrencejmcook
Posts 742
This occasionally happened to me with my BV5 and my Sky+ box.
The fix was to go to the Connections menu and set up the STB box from scratch - choose the box from the list. Then Switch off and on again.
Lawrence
noby39
Posts 13
noby39 replied on Fri, Feb 27 2015 4:42 PM
Thanks for your reply, Lawrence.
I tried the solution that you suggested but the problem remains.
I've decided to hand the problem to the local B&O technician.
Noel
Page 1 of 1 (3 items) | RSS
