I own a BeoVision 6. It is connected to a Sky + set top box. Recently the B&O handheld controller stopped working with the Sky + box, but otherwise works with the Menu, Exit, etc functions on the TV . I can change channels, etc. on the BeoVision 6 using the Sky handheld controller. I checked that the cable running from the IR-Out on the BeoVision 6 to the Sky + box is connected to the TV but I'm unable to test if there is a signal on that cable. Any suggestions would be welcomed.
Thanks for your reply, Lawrence.
I tried the solution that you suggested but the problem remains.
I've decided to hand the problem to the local B&O technician.
Noel
