Beolab 2 scratches
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Mon, Apr 20 2015 5:53 PM
There a a few scrathes on my new Beolab 2. Is it possible to remove them in any way? They are on the bottom, so not that noticable, but if it is easy to remove them, it would give me peace of mind.
Sal
California, USA
Posts 1,197
Sal replied on Mon, Apr 20 2015 6:36 PM
Two questions as I also owned a BL2 in the past and had one scratch / mark.
How deep are the scratches, are they a different color than the silver paint?
Are they actually scratches, or detritus on the finish which merely looks like scratches?
Sometimes, the act of removing the marks / scratches can leave the BL2 in worse shape than leaving the mark alone.
leosgonewild
Helsinki, Finland
Posts 2,373
Chris
Ostend-BE
Posts 1,170
Chris replied on Mon, Apr 20 2015 7:40 PM
Its luckily on the bottom, I would buy some dark grey silver and black paint from a modeling shop. They sell these colours in small tins, and mix some black in to the silver. First do a few tests in color mixing on a piece of plastic, then try to update the scratches with a fine brush.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Mark
London
Posts 1,063
Mark replied on Tue, Apr 21 2015 9:00 AM
If it's a painted surface try Farcela G3, they do a range of automotive scratch remover pastes and liquids. It may not rid the scratch completely but will soften the appearance.
Page 1 of 1 (5 items) | RSS
