Beo 7.32 - No sound
This post has 12 Replies | 2 Followers
KeithMM
Posts 11
KeithMM Posted: Sun, May 17 2015 8:06 PM
Having recently setting up one of my Beovision 7.32 Tvs ..... I managed to connect my Sky box and receive this on V.MEM I'm now not receiving any sound from the TV
Can someone help?
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, May 17 2015 9:28 PM
What speakers do you have connected?
I assume you mean you have picture from the Sky box but no sound?  How and where have you connected the box to the TV?
If you press 'List' until 'Speaker' is on the BEO4, press, 1,2, or 3 depending on which speakers you have connected.  Do you now get sound?
Dave.
elephant
AU
Posts 8,219
elephant replied on Sun, May 17 2015 10:54 PM
Or use menu to go to sound and do the hiss test. That should help determine if the problem is between the sky and the BV
BeoNut since '75
KeithMM
Posts 11
KeithMM replied on Mon, May 18 2015 9:28 AM
Hi Dave
Right..... I've connected my BOSE speakers through the earphone socket! These work perfectly well with a DVD. No other speakers are attached!!
SKY is through the DVI-I port on the TV
I don't know if Ive switched something off in the tv settings when I connected the Sky Box!!
HELP!!!!!!!!
KeithMM
Posts 11
KeithMM replied on Mon, May 18 2015 9:30 AM
Cant even fond the settings to do the hiss test! [ :(]
HELP!!!!!!!!
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, May 18 2015 9:34 AM
DVI-I port only provides picture but no sound!
You have to connect 'Sky' also via digital or analogue sound cable(s).
Regards
Räuber
KeithMM
Posts 11
KeithMM replied on Mon, May 18 2015 9:49 AM
 Thanks Räuber     Thats why!  Right where would I put the digital cables in to on the set?
Keith
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, May 18 2015 10:20 AM
Hello Keith,
as far I can see in manual of BV 7-32 you can use one of the four 'DIGITAL AUDIO IN, A1-A4' to connect a coaxial cable to get sound, if video is connected via DVI-IN.
But your 'Sky' must have also a digital coaxial sound output. If it has a digital optical sound output you have to use a converter (optical to coaxial). If it has only an analogue sound output you have to use two cables and connect it to AV4 inputs L and R.
Good luck!
Räuber
BeoMotion
Posts 384
BeoMotion replied on Mon, May 18 2015 12:14 PM
if your TV SW isn't from the stoneage I would recommend you to connect your SKY box via a scart cable to e.g. AV1 or AV2 as well as to the DVI connector.
In connection menu of AV1/2 you are then able to select DVI input.
This has the advantage that audio is feed from the SCART cable.
If you ever want to control your SKY box via PUC the scart cable is also necessary for on/off sensing.
BR,
BeoMotion.
Seanie_230
UK
Posts 2,278
Hi Keith
You could also connect the optical out of the sky box via a optical / tosh link convertor (about £10) and connect to a av port Would give you Dolby also if you have more speakers connected.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
KeithMM
Posts 11
KeithMM replied on Mon, May 18 2015 7:40 PM
That did the trick! I have sound to match the HDMI picture
Many, many thanks
Keith
KeithMM
Posts 11
KeithMM replied on Mon, May 18 2015 7:42 PM
Thanks Sean
..... now where do I put that IR Lead!  C1 output?
Keith
BeoMotion
Posts 384
BeoMotion replied on Mon, May 18 2015 9:07 PM
KeithMM:
You can choose one of the four. Just make sure that the right one is selected in menu.
Also pay attention that you select the matching PUC to your SKY box. If the right one is not in the list you might want to contact you local dealer.
BR,
BeoMotion.
Page 1 of 1 (13 items) | RSS
