Having recently setting up one of my Beovision 7.32 Tvs ..... I managed to connect my Sky box and receive this on V.MEM I'm now not receiving any sound from the TV
Can someone help?
What speakers do you have connected?
I assume you mean you have picture from the Sky box but no sound? How and where have you connected the box to the TV?
If you press 'List' until 'Speaker' is on the BEO4, press, 1,2, or 3 depending on which speakers you have connected. Do you now get sound?
Dave.
BeoNut since '75
Hi Dave
Right..... I've connected my BOSE speakers through the earphone socket! These work perfectly well with a DVD. No other speakers are attached!!
SKY is through the DVI-I port on the TV
I don't know if Ive switched something off in the tv settings when I connected the Sky Box!!
HELP!!!!!!!!
Cant even fond the settings to do the hiss test! [ :(]
Thanks Räuber Thats why! Right where would I put the digital cables in to on the set?
Keith
if your TV SW isn't from the stoneage I would recommend you to connect your SKY box via a scart cable to e.g. AV1 or AV2 as well as to the DVI connector.
In connection menu of AV1/2 you are then able to select DVI input.This has the advantage that audio is feed from the SCART cable.If you ever want to control your SKY box via PUC the scart cable is also necessary for on/off sensing.
BR,BeoMotion.
Eclipse 65V1-32Beosound M5Essence MK2BLI
That did the trick! I have sound to match the HDMI picture
Many, many thanks
Thanks Sean
..... now where do I put that IR Lead! C1 output?
KeithMM:now where do I put that IR Lead! C1 output
