Beosound essence remote light control mode
This post has 5 Replies | 0 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Tue, May 26 2015 1:52 PM
I set the remote to light mode.
Turning the wheel turns the light on, and I can adjust it up and down.
But I can not turn it off?? Any ideas?
It is controlling a LC2, and the LC2 is set to factory defaults.
leosgonewild
Helsinki, Finland
Posts 2,373
I tried it also with my bosscom light dimmer, and it seems like the essence remote is only sending up/down commands when turning the wheel. Pressing the buttons does not seem to send an ir command to the dimmer.
leosgonewild
Helsinki, Finland
Posts 2,373
Turns out I would need a MLGW :(
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, May 26 2015 6:44 PM
A Lintronic box should also work. Essence remote sends function commands in LIGHT mode.
Lintronic can convert these commands.
Stefan
leosgonewild
Helsinki, Finland
Posts 2,373
Do you have some more info? Link?
I can´t find anything on google..
stefan
Posts 2,920
stefan replied on Tue, May 26 2015 7:53 PM
Quite simple.
Look at the Beointegration site - technical inspiration - Essence remote key mapping.
Go to Lintronic.dk . Lintronic can receive function commands in LIGHT mode and is able to send Beo LIGHT commands like PLAY, STOP...
Should even be possible to create macros (scenes) in this way.
I don't think anybody has tried it because the Essence remote is quite new.
But I'm sure it will work...;)
Stefan
Page 1 of 1 (6 items) | RSS
