I set the remote to light mode.
Turning the wheel turns the light on, and I can adjust it up and down.
But I can not turn it off?? Any ideas?
It is controlling a LC2, and the LC2 is set to factory defaults.
I tried it also with my bosscom light dimmer, and it seems like the essence remote is only sending up/down commands when turning the wheel. Pressing the buttons does not seem to send an ir command to the dimmer.
Turns out I would need a MLGW :(
A Lintronic box should also work. Essence remote sends function commands in LIGHT mode.
Lintronic can convert these commands.
Stefan
Do you have some more info? Link?
I can´t find anything on google..
Quite simple.
Look at the Beointegration site - technical inspiration - Essence remote key mapping.
Go to Lintronic.dk . Lintronic can receive function commands in LIGHT mode and is able to send Beo LIGHT commands like PLAY, STOP...
Should even be possible to create macros (scenes) in this way.
I don't think anybody has tried it because the Essence remote is quite new.
But I'm sure it will work...;)
