CDX integration with Beomaster
This post has 1 Reply | 2 Followers
joetpayne
Posts 17
joetpayne Posted: Sat, May 30 2015 12:41 PM
I have just bought a CDX and a beomaster 3300.
The sound is great but I wanted to know if it was possible to replace the RCA output from the CDX with a seven pin din connection so that I can control the CDX with the remote for the beomaster. Would this be possible?
To that extent, does anybody know if it is possible to buy a seven pin din switch so I can expand the number of B&O inputs I can connect to the beomaster. I quite want to connect another B&O cd player (crazy, I know) but the beomaster 3300 only has 1 cd, 1 tape and 1 phono input.
Thanks for the help!!
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, May 30 2015 12:49 PM
Welcome to Beoworld!
To put it bluntly, there is no way this can be done.
The proper model for that is the Beogram CD3300, based on the later TDA1541 chip.
B&O did produce CD extension boxes.
They do show up from time to time on eBay.
http://www.beoworld.org/prod_details.asp?pid=762
Jacques
Page 1 of 1 (2 items) | RSS
