I have just bought a CDX and a beomaster 3300.
The sound is great but I wanted to know if it was possible to replace the RCA output from the CDX with a seven pin din connection so that I can control the CDX with the remote for the beomaster. Would this be possible?
To that extent, does anybody know if it is possible to buy a seven pin din switch so I can expand the number of B&O inputs I can connect to the beomaster. I quite want to connect another B&O cd player (crazy, I know) but the beomaster 3300 only has 1 cd, 1 tape and 1 phono input.
Thanks for the help!!
Welcome to Beoworld!
To put it bluntly, there is no way this can be done.
The proper model for that is the Beogram CD3300, based on the later TDA1541 chip.
B&O did produce CD extension boxes.
They do show up from time to time on eBay.
http://www.beoworld.org/prod_details.asp?pid=762
Jacques
