Beovox 3702 cables
This post has 4 Replies | 2 Followers
Thrainsson
Posts 3
Thrainsson Posted: Sun, Jan 24 2016 2:33 PM
I have Beovox 3702 speakers. Somone had cut the cables close to the back. Does anyone know how I can replace the cables?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jan 24 2016 6:52 PM
Welcome to Beoworld !
Take off the front panels, losen the woofer and swing it aside.
This will give you access to the crossover filter boards.
The cables are soldered to the boards so easily replaced.
Use 2x0,75mm2 cable and make sure to get the polarity right.
Thrainsson
Posts 3
Thank you for the information! Have removed the woofer, how do I see which wire is plus or minus?
Dillen
Posts 13,191
Dillen replied on Mon, Jan 25 2016 9:25 PM
You can refer to the schematics.
Some original cables have a grey stripe down the positive lead. Maybe you can spot this on the
remaining piece of cable.
Thrainsson
Posts 3
Thrainsson replied on Mon, Jan 25 2016 10:13 PM
The speakers are connected now, sound good! thanks for all the help!
Page 1 of 1 (5 items) | RSS
