I have Beovox 3702 speakers. Somone had cut the cables close to the back. Does anyone know how I can replace the cables?
Welcome to Beoworld !
Take off the front panels, losen the woofer and swing it aside.This will give you access to the crossover filter boards.The cables are soldered to the boards so easily replaced.Use 2x0,75mm2 cable and make sure to get the polarity right.
Thank you for the information! Have removed the woofer, how do I see which wire is plus or minus?
You can refer to the schematics.Some original cables have a grey stripe down the positive lead. Maybe you can spot this on theremaining piece of cable.
The speakers are connected now, sound good! thanks for all the help!
