Eclipse 65V1-32Beosound M5Essence MK2BLI
Well done on getting a 7-55. Awesome TV!
Have you tried the speaker roles with the AST on, or off?
Exactly where did you find the 'HW' info? I found something similar on mine and there were 2 items listed but not titled 'socket panel'. Maybe version differences between yours and mine?
What option setting is the BV7 in? Maybe the other TV's are competing to be 'master'.
It took me ages to get mine fullt set-up and then I went and changed speakers, added a BL2, moved the TV etc so had to do a lot all over again!
There are some quirks with this TV's operation. Like when watching a DVD - if I pause it, I have to use the yellow arrow key followed by 'go' to restart it. I can't find another way that works!
Dave.
Dave Farr: There are some quirks with this TV's operation. Like when watching a DVD - if I pause it, I have to use the yellow arrow key followed by 'go' to restart it. I can't find another way that works! Dave.
Raeuber:if you use a Beo4 with navi button you don't need the yelloe arrow key anymore.
I've already got 7 BEO4's. Not with a navi button though. I can live with pushing two buttons for now.
Raeuber:I only know that on BV 7 in LINK-TUNING menue it has to be set to AUTOMATIC.
Hi there
I have plugged back in my 7-40 and link room functions work perfectly again.
I have checked the link room tv's setup and they are all fine.
Maybe the modulator is different from a TV from france ???
Maybe Leo is interested in getting the -55
Millemissen:Maybe Leo is interested in getting the -55 MM There is a tv - and there is a BV.
Seanie_230:Sky HD PUC is a little haywire too. Pressing up on the beo4 or beolink app once is fine but if I press twice the reaction on the sky box is it jumps up loads of times.
This may be normal. I have a STB that will do similar - 1 push and 1 channel up or down, double fast button push = 10 stations up or down for faster searching through many channels.
Hope you get it all sorted out and can enjoy your TV.
Bravo!
Enjoy your new tv.
Raeuber:Congratulations! I already mentioned B/G and I setting on my link TV. Although I don't know what this setting exactly means. Regards Räuber
Millemissen:Bravo! Enjoy your new tv. MM There is a tv - and there is a BV.
Very nice upgrade.
Beoplay A2
Hi, Just saw this post, set your BV 7-55 modulator to system I for the UK link TVs then you will have sound I presume the link TVs are UK tvs, the 7-55
will be set to the French Analogue TV system
