New Beovision 7-55 MK2
This post has 25 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, Apr 22 2015 10:35 PM
Hello all
Today I got a used Beovision 7-55 Mk2. I have some observations and questions
When swapping my 7-40 to the 7-55 the gateway must automatically update itself as my macros for light commands started working again.
The puc for sky hd seems to be a little crazy, when you scroll up one press at s time it's fine but if you press twice in a row it seems to jump about 10 lines on the sky box.
In the service menu under HW there is a part that says Socket Panel this says unknown what should it say? Or is unknown fine?
My link TV's are not working as they were, now they come on and have sound for a second or so and sound goes away, if I toggle from to DTV sound comes back for a few seconds and then goes again. I can force sound to come through by selecting AV DTV and I assume this pulls sound over ML rather than over the modulator. I changed the modulator channel and that does not fix anything. This happens on all my link tv's
When I go to select speaker roles I get front left and right, right and left surround and rear centre but not the options I had on 7-40 which I believe was rear surround and rear speakers for full 7.1
Any thoughts all?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Apr 23 2015 11:37 AM
Well done on getting a 7-55.  Awesome TV!
Have you tried the speaker roles with the AST on, or off?
Exactly where did you find the 'HW' info?  I found something similar on mine and there were 2 items listed but not titled 'socket panel'.  Maybe version differences between yours and mine?
What option setting is the BV7 in?  Maybe the other TV's are competing to be 'master'.
It took me ages to get mine fullt set-up and then I went and changed speakers, added a BL2, moved the TV etc so had to do a lot all over again!
There are some quirks with this TV's operation.  Like when watching a DVD - if I pause it, I have to use the yellow arrow key followed by 'go' to restart it.  I can't find another way that works!
Dave.
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Apr 23 2015 3:50 PM
Dave Farr:
Dave.
Hello Dave,
if you use a Beo4 with navi button you don't need the yelloe arrow key anymore.
Regards
Räuber
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Apr 23 2015 4:53 PM
Hello Seanie,
if I would get a used BV 7-55 Mk 2 first of all I would start a reset to factory settings in the service menue.
Check also if installed software version is the latest: BUILD 1112
BTW: SOCKET PANEL = UNKNOWN is correct.
Regards
Räuber
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Apr 23 2015 5:22 PM
Raeuber:
I've already got 7 BEO4's.  Not with a navi button though.  I can live with pushing two buttons for now.
Dave.
Seanie_230
UK
Posts 2,278
Hi there
Thanks for the clarification on the socket panel.
The TV is at build 1112
I might try another av port for the SD dist and see if it makes a difference.
Just been around to both link TV's and confirmed option 6.
If I press DTV I get sound and picture for about two seconds and it goes along with the picture jumping to another position. If I toggle from DTV to TV and then back to DTV I get sound and picture for two seconds and it goes again.
Any thoughts?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Apr 23 2015 10:26 PM
Which TVs do you have in your linkrooms?
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Thu, Apr 23 2015 10:28 PM
Hi there
A
Beovision 3-32 and 6-26
Both have the exact same issue and did not before when using the 7-40 as the master.
Pressing av DTV pulls the sound in via ml so the connection is there
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Apr 23 2015 10:49 PM
Hi Seanie,
I have a BV 10 in linkroom. With BV 7-40 Mk6 in mainroom the trick is:
press MENU on Beo4 (in linkroom)
OPTIONS
CONNECTIONS
LINK-TUNING
set TV-SYSTEM to 'B/G' (not 'I'; with 'I' I can't get also no sound from BV 7 on BV 10)
Hope this helps.
Regards
Räuber
Seanie_230
UK
Posts 2,278
Hi there
My beovision 3 and 6 don't have the option for that
But we may be closer. My TV is from France so is there a change that might need to be made on the modulator on the beovision 7-55?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Apr 24 2015 7:37 AM
I only know that on BV 7 in LINK-TUNING menue it has to be set to AUTOMATIC.
Seanie_230
UK
Posts 2,278
Raeuber:
Yeah mine is on auto too
Problem with the puc and link rooms to go
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Apr 24 2015 9:21 AM
Did you check the MODULATOR SETUP menue at link TVs? See page 63 of BC 6-26 manual.
Seanie_230
UK
Posts 2,278
Hi there
I have plugged back in my 7-40 and link room functions work perfectly again.
I have checked the link room tv's setup and they are all fine.
Maybe the modulator is different from a TV from france ???
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Millemissen
Flensborg, Denmark
Posts 14,680
Maybe Leo is interested in getting the -55 Whistle
Seanie_230
UK
Posts 2,278
Millemissen:
I'm keeping the 55 just need my link rooms to work.
Sky HD PUC is a little haywire too. Pressing up on the beo4 or beolink app once is fine but if I press twice the reaction on the sky box is it jumps up loads of times.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Apr 24 2015 2:36 PM
Seanie_230:
This may be normal.  I have a STB that will do similar - 1 push and 1 channel up or down, double fast button push = 10 stations up or down for faster searching through many channels.
Hope you get it all sorted out and can enjoy your TV.
Dave.
Seanie_230
UK
Posts 2,278
Does anyone know where in the service menu I can change the modulator output type
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hello all
The solution is
Go into service menu and change modulator output from BG to I for UK
Now all link video works perfectly :)
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Apr 24 2015 8:31 PM
Congratulations!
I already mentioned B/G and I setting on my link TV. Although I don't know what this setting exactly means.
Regards
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
Bravo!
Enjoy your new tv.
Seanie_230
UK
Posts 2,278
Raeuber:
Congratulations!
Regards
Räuber
Thank you
I could not find the setting on link tv's but I found it on my main TV.
I believe these are the transmission settings for different countries.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Millemissen:
Bravo!
Enjoy your new tv.
Thank you.
Will do
Before
After
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
markiedee
UK
Posts 425
markiedee replied on Fri, Apr 24 2015 9:38 PM
Very nice upgrade.
Beoplay A2
Seanie_230
UK
Posts 2,278
Little and large
Bv7-40 just left. We may have a new member this evening
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Douglas
Edinburgh & Essen, Germany
Posts 58
Hi, Just saw this post, set your BV 7-55 modulator to system I for the UK link TVs then you will have sound I presume the link TVs are UK tvs, the 7-55
will be set to the French Analogue TV system
Page 1 of 1 (26 items) | RSS
