my beovision 9 has a problem with its power lead the power goes into the tv but has no power coming back out to the beosytem 3 does it have a fuse inside inside the tv? also is it ok to run a power cable straight into the beosytem 3
Yes you can put a separate cable to the bs3
Thanks for your quick reply
