beovision 9 power lead problem
This post has 4 Replies | 0 Followers
mbdj
Posts 74
mbdj Posted: Fri, Jun 12 2015 4:45 PM
my beovision 9 has a problem with its power lead the power goes into the tv but has no power coming back out to the beosytem 3 does it have a fuse inside inside the tv? also is it ok to run a power cable straight into the beosytem 3
Jason
Redditch Worcestershire
Posts 177
Jason replied on Fri, Jun 12 2015 5:32 PM
Yes you can put a separate cable to the bs3
mbdj
Posts 74
mbdj replied on Fri, Jun 12 2015 6:32 PM
Thanks for your quick reply
mbdj
Posts 74
Radiomekaniker
Posts 49
There is a power distribution circuit board inside the TV.
Page 1 of 1 (5 items) | RSS
