Hello!
My question is concerning TV sound on ML devices
My setup:
BV Avant75 in main room; connected via ML/NL converter to BS9000 (AMaster), BS5/BM5 combo and BS3200 in kitchen
I can listen to n.music and n.radio of course in main room with Avant - no problem there; also no problem listening to n.music and n.radio on BS3200;
command Radio and CD on BS32000 does not switch the BS9000 on - BS3200 working as stand alone
I would like to listen to "TV sound" on BS3200 which I am not able to do.
operation instruction says push "AV" and then "TV" on Beo4 (one with AV as hard button) - but there is no reaction from BS3200
sorry - can not provide audio option setting of BS3200...maybe there is the fault?!?
Someone any idea?
Best regards
Elmar
f5434964:Hello! My question is concerning TV sound on ML devices My setup: BV Avant75 in main room; connected via ML/NL converter to BS9000 (AMaster), BS5/BM5 combo and BS3200 in kitchen I can listen to n.music and n.radio of course in main room with Avant - no problem there; also no problem listening to n.music and n.radio on BS3200; command Radio and CD on BS32000 does not switch the BS9000 on - BS3200 working as stand alone I would like to listen to "TV sound" on BS3200 which I am not able to do. operation instruction says push "AV" and then "TV" on Beo4 - but there is no reaction from BS3200 sorry - can not provide audio option setting of BS3200...maybe there is the fault?!? Someone any idea? Best regards Elmar
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
