TV Sound via ML/NL Converter
f5434964
Austria
Posts 206
f5434964 Posted: Sun, Jun 21 2015 2:08 PM
Hello!
My question is concerning TV sound on ML devices
My setup:
BV Avant75 in main room; connected via ML/NL converter to BS9000 (AMaster), BS5/BM5 combo and BS3200 in kitchen
I can listen to n.music and n.radio of course in main room with Avant - no problem there; also no problem listening to n.music and n.radio on BS3200;
command Radio and CD on BS32000 does not switch the BS9000 on - BS3200 working as stand alone
I would like to listen to "TV sound" on BS3200 which I am not able to do.
operation instruction says push "AV" and then "TV" on Beo4 (one with AV as hard button) - but there is no reaction from BS3200
sorry - can not provide audio option setting of BS3200...maybe there is the fault?!?
Someone any idea?
Best regards
Elmar
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Jun 21 2015 2:13 PM
f5434964:
Hello!
My setup:
operation instruction says push "AV" and then "TV" on Beo4 - but there is no reaction from BS3200
Someone any idea?
Best regards
Elmar
You need to make sure the mapping in NL/ML converter is correct. You have to make the settings so that the ML command AV TV is mapped to TV on the NL.
Page 1 of 1 (2 items) | RSS
