Just saw, that there was a small update on my V1.
Not much, but something, that I have had wished for...
With an earlier update a 'time out' for the screen - when playing from Spotify... or audio from H.Media - was introduced. Very annoying, as I found.
Now you can choose to keep this 'time-out', to have no picture showing or to have it always on.
I prefer 'always on', as I like to see, what I listen to.
Bravo - thanks for that.
Now we just need Spotify to update their TV apps.
It's quite annoying that it's still based on the old "Starred" format. Spotify changed from "Starred" songs to "My music" quite some time ago. And all music located in the new folders are not shown in the TV-app.
Beovision Eclipse gen2 (GX) w/ floorstand, Beolab 14.2, 4 speaker Shape and ATV4/Chromecast.
Beoplay A9mk4 GVA, Beosound 1 GVA, H2, H3, H8, E6, Beoplay EQ
Millemissen:Now you can choose to keep this 'time-out', to have no picture showing or to have it always on.
Nice update regarding the screen blankingAlso the 'Teletekst' issue that we experienced in NL has now been solved.Hope they will add ALAC support for home media in a next update.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael:I got the update on my avant and v1 also. Still can't let speaker group be left unchanged when changing source. Very annoying. Very.
Start Avant
Select menu
Select Source list
Place the cursor on a source
Select red-button (set-up)
Select Advanced setting
Select Speaker groups; adjust to the preferred group
Store settings
Repeat for all sources and choose the same speaker group for all the sources.
Than at least, with most normal day to day use you will have NO switching of groups between different sources
Here's the text from the HELP (blue button) when you're in the choices for the new Picture Off setting with the SW Update:
Selecting NEVER means that the screen switches on, when you select the audio source and the picture/menu remains on the screen. However, you can remove the picture from the screen by using the remote control cue 'PICTURE OFF'
Shouldn't the description state "PICTURE MUTE" as the remote control function to use, or is "PICTURE OFF" a valid term on the BeoRemote One or more modern remote?
Maybe it's just me, but I can't for the life of me see why you would want to do that? Surely that would completely defeat the purpose of having speaker groups anyway?
rednik: Maybe it's just me, but I can't for the life of me see why you would want to do that? Surely that would completely defeat the purpose of having speaker groups anyway?
These are two eays of hadling speakers group.
Even if they wanted to do Michael that favour, I am not sure, that it would be possible to implement both - at least not if you want to maintain simplicity of using the speaker groups.
Sal: Shouldn't the description state "PICTURE MUTE" as the remote control function to use, or is "PICTURE OFF" a valid term on the BeoRemote One or more modern remote?
surely one could have picked another description of these additional settings.
As I see it - how it is made in the settings, is that one can set the preferences (that you usually don't change that often).
P.Mute is something, that you actively do, if you need it in a certain situation - e.g. you can P.Mute the news on tv or P.Mute Youtube, if you just want to listen.
Anyway - regardless of which terms the choose for these settings/actions, I am pleased to have these choises now.
Carolpa:Start Avant Select menu Select Source list Place the cursor on a source Select red-button (set-up) Select Advanced setting Select Speaker groups; adjust to the preferred group Store settings Repeat for all sources and choose the same speaker group for all the sources. Than at least, with most normal day to day use you will have NO switching of groups between different sources
I tried answering from my phone with the app but the answer disappeared. Anyway. Regarding speaker groups. I find it much more realistic to have them to choose from for different occasions, such as nighttime, party, movie time or just background TV or different placements. I find it less realistic that most people want different speaker groups for different sources. Of course there are reasons for this but not everyone wants that I am sure (I am one of them). Most systems out there works on the principle I suggest. It should be super easy for B&O to address this in software. Super easy.
Millemissen: surely one could have picked another description of these additional settings. As I see it - how it is made in the settings, is that one can set the preferences (that you usually don't change that often). P.Mute is something, that you actively do, if you need it in a certain situation - e.g. you can P.Mute the news on tv or P.Mute Youtube, if you just want to listen. Anyway - regardless of which terms the choose for these settings/actions, I am pleased to have these choises now. MM
I am happy to have this as an option.
My point was that if B&O were going to state a remote control option in the description, shouldn't they have gotten the actual words which you choose on the remote control exactly right? Is there "PICTURE OFF" or "PICTURE MUTE" as a choice on a Beo4 or BeoReoremote One? If there isn't a "PICTURE OFF" menu option on a Beo4 or BeoRemote One, then don't use those words -- especially when formulating a help description.
Michael:I find it less realistic that most people want different speaker groups for different sources. Of course there are reasons for this but not everyone wants that I am sure (I am one of them).
Personally, I like to listen to radio using just the built-in speaker of my BV 11, while I use only the front external speakers for Spotify, so I'm one of the few appreciating the ability to set a specific group per source :)
Marcello: ... so I'm one of the few appreciating the ability to set a specific group per source :)
i am not sure, that we are few - it is my choice too.
Although it may be a bit offtopic in this thread - it would be nice to hear from others, how (or if) they use speaker groups?
A lot - probably - will use them 'as installed', when the tv was setup.
My Setup and Speaker Groups:
Setup: BV11-55 connected to a pair of BL9's.
Speaker Groups:
Regular TV (TiVO): BV11 speakers only
Spotify / HomeMedia: BL9s only (I use HomeMedia for music only)
Apple TV: BV11 as center + BL9 as L and R (I use Apple TV for movies, etc)
