I, too, have been planning on having Lutron shades installed. How long did it take to get your shades once you ordered them through your dealer? I've found that the lead time on some Lutron products can be very long.
Eclipse 65V1-32Beosound M5Essence MK2BLI
beojeff:I, too, have been planning on having Lutron shades installed. How long did it take to get your shades once you ordered them through your dealer? I've found that the lead time on some Lutron products can be very long.
Seanie_230:Hi there I am thinking of buying the curtain track. How does communication work are these products are individual with IP control or do you have to buy certain things??? BLGW - Rekindling the love of ML
You need a Lutron system, such as the RadioRa 2. For the RadioRa 2, you would need to buy the Main Repeater, which can interface with the B&O Gateway by either IP or RS232. I prefer the RS232 connection as it's more stable. The Main Repeater will cost you around $350 USD. Most Lutron installers will require you to have them do the programming using there Lutron software -- unless you happen upon a friendly installer who will provide you with the Windows software program. As was previously mentioned by the original poster, these shades are rather expensive. I was quoted a minimum of $4000 to $6000 for the Lutron shades that I selected, which would be two shades for very large windows in a refurbished factory loft.
