BeoLab 3500 loudness ON
vvrhf
Posts 5
Silver Member
vvrhf Posted: Thu, May 23 2019 11:09 AM
Good day
I have the following setup
BeoSound 9000 + 2x BeoLab 3500  + BeoLab 4 + 2xBeoLink Active + 1xBeoLink Passive
I can NOT switch on Loudness on both my 3500s and BeoLab 4.
I can adjust volume/bass/balance but when trying to change loudness from OFF to ON nothing happens. It  shows OFF.
I've tried to do it with Beo4, Beo 1000.
Meanwhile, the loudness on BeoSound 9000 can be switched ON and OFF
Could You help me with this issue.
MJ
Posts 59
MJ replied on Sat, May 25 2019 10:49 AM
Did you try to adjust settings (on a beo4 remote) via List>A.SETUP>LOUDNESS? If not you have to add A.SETUP on the remote settings.
You should be able to change loudness when LOUDNESS is shown in the beo4 display by pressing the up and down arrow.
The display on your Beolab 3500 will show ‘LOUDNESS’ when loudness is on, and alternating ‘LOUDNESS’ and ‘OFF’ when loudness is off.
Hope this helps
vvrhf
Posts 5
Silver Member
vvrhf replied on Sat, May 25 2019 11:06 AM
Goo day
Thanks for the answer.
I tried to do it with Beo4, the issue is the same. I see loudness on 3500 lcd but when pressing up/down it shows only OFF, I can not switch it ON.
Page 1 of 1 (3 items) | RSS
