Based on the placement of the left one - which is the only one, I can see - it's ok.
I would do so too.
Hey Chris, I hope you enjoy your BL9's as much as I enjoy mine.
See how they sound to you and try the other settings too. Your ears will decide what is best for you. They are probably enough into the corner to call them 'corner' but try others too - it's only a flick of a switch. Don't forget to adjust all of the other speaker settings too for distance etc. I found a BL2 worked wonders for films and music in my system.
Dave.
BeoGreg:Very serious setup, congrats. It will never end !
Chris Townsend:The wife said she definitely can, and we should now buy a Beosound 9000 immediately [:\'(]
