PUC Cable
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Sat, Jul 11 2015 7:59 AM
Hi
I saw a post here recently about the PUC cable and the little "stickem" that B&O use to hold them in place
Was wondering do those little stickems (double sided small tape things) just come with PUC cables or can you get them?
I recently swapped my Foxtel box for the latest foxtel box and although my Remote One works with the box it has trouble powering on so i need to reposition the IR over the box.
I tried tape but that looks ordinary and i can't get it right. I asked the Shop and they said super glue (hmmm), but id rather try those little pieces of double sided tape that the installer used as i didnt have an issue with it.
All help appreciated. Thanks
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Jul 11 2015 11:01 AM
Not advertising the stuff,but I'm going to give this a go as the surface  over the digibox sensor is not flat and the puc sticker did not adhere. https://sugru.com
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Aussie Michael
Melbourne, AU
Posts 3,730
lol.. i loved it when it said WTF is ... :-)
But isn't the issue that you cant cover the sensor with something solid so it wont see the IR?
Aussie Michael
Melbourne, AU
Posts 3,730
btw that stuff is amazing :-)
BeoMotion
Posts 384
BeoMotion replied on Sat, Jul 11 2015 11:44 AM
I really can recommend those little plastic caps from STB.
It is a little case that is surrounded with special glue where you put in the existing IR blaster.
Will stay in place for ever...
http://www.stbbrackets.co.uk/en-GB/product/ir-transmitter/internal-ir-cover
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Jul 11 2015 12:15 PM
BeoMotion:
Looks to be the solution, but I only need one.
perhaps Lee could buy a pack of ten and sell them individually to Beoworld members!
Aussie Michael
Melbourne, AU
Posts 3,730
BeoMotion:
I really can recommend those little plastic caps from STB. It is a little case that is surrounded with special glue where you put in the existing IR blaster. Will stay in place for ever...
Thanks . Someone did mention these, however how does it work if it the STB covers the whole IR sensor?
I had the issue originally where the IR cable end has to be off-centre to the IR sensor of your equipment.
May i ask what equipment you use the STB stickems for?
BeoMotion
Posts 384
BeoMotion replied on Sat, Jul 11 2015 1:04 PM
Before you put this cap on you need to know the exact position where the IR blaster is working correctly.
Then you lay the IR blaster into the STB cap and put it on this location. I use it e.g. on an Apple TV.
To come back to your initial question:
All B&O IR blasters come with a little double-sided tape attached to the front.
If it is not sticky enough anymore and you don't want to use another method for attaching you could try to replace this adhesive.
It should be something like this: http://www.digikey.de/product-detail/en/12X12-6-467MP/3M9726-ND/2649271
It is called "adhesive transfer tape" and is basically the same that holds your smartphones touchscreen in place.
Transparent and without a carrier layer.
Aussie Michael
Melbourne, AU
Posts 3,730
BeoMotion:
Before you put this cap on you need to know the exact position where the IR blaster is working correctly. Then you lay the IR blaster into the STB cap and put it on this location. I use it e.g. on an Apple TV.
To come back to your initial question: All B&O IR blasters come with a little double-sided tape attached to the front. If it is not sticky enough anymore and you don't want to use another method for attaching you could try to replace this adhesive. It should be something like this: http://www.digikey.de/product-detail/en/12X12-6-467MP/3M9726-ND/2649271 It is called "adhesive transfer tape" and is basically the same that holds your smartphones touchscreen in place. Transparent and without a carrier layer.
Thank you
Page 1 of 1 (9 items) | RSS
