Not advertising the stuff,but I'm going to give this a go as the surface over the digibox sensor is not flat and the puc sticker did not adhere. https://sugru.com
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
I really can recommend those little plastic caps from STB. It is a little case that is surrounded with special glue where you put in the existing IR blaster.Will stay in place for ever...
http://www.stbbrackets.co.uk/en-GB/product/ir-transmitter/internal-ir-cover
BeoMotion: I really can recommend those little plastic caps from STB. It is a little case that is surrounded with special glue where you put in the existing IR blaster.Will stay in place for ever... http://www.stbbrackets.co.uk/en-GB/product/ir-transmitter/internal-ir-cover
Looks to be the solution, but I only need one.
perhaps Lee could buy a pack of ten and sell them individually to Beoworld members!
BeoMotion:I really can recommend those little plastic caps from STB. It is a little case that is surrounded with special glue where you put in the existing IR blaster. Will stay in place for ever... http://www.stbbrackets.co.uk/en-GB/product/ir-transmitter/internal-ir-cover
Before you put this cap on you need to know the exact position where the IR blaster is working correctly.Then you lay the IR blaster into the STB cap and put it on this location. I use it e.g. on an Apple TV.
To come back to your initial question: All B&O IR blasters come with a little double-sided tape attached to the front.If it is not sticky enough anymore and you don't want to use another method for attaching you could try to replace this adhesive. It should be something like this: http://www.digikey.de/product-detail/en/12X12-6-467MP/3M9726-ND/2649271It is called "adhesive transfer tape" and is basically the same that holds your smartphones touchscreen in place. Transparent and without a carrier layer.
BeoMotion:Before you put this cap on you need to know the exact position where the IR blaster is working correctly. Then you lay the IR blaster into the STB cap and put it on this location. I use it e.g. on an Apple TV. To come back to your initial question: All B&O IR blasters come with a little double-sided tape attached to the front. If it is not sticky enough anymore and you don't want to use another method for attaching you could try to replace this adhesive. It should be something like this: http://www.digikey.de/product-detail/en/12X12-6-467MP/3M9726-ND/2649271 It is called "adhesive transfer tape" and is basically the same that holds your smartphones touchscreen in place. Transparent and without a carrier layer.
