Essence MK 2 received.
This post has 65 Replies | 4 Followers
mjmedlo
Posts 922
mjmedlo Posted: Tue, Aug 11 2015 9:33 PM
Hope to hook it up tonight.
Assume it's the same except it will show up on the BeoMusic App.
Will advise.
elephant
AU
Posts 8,219
elephant replied on Tue, Aug 11 2015 11:34 PM
"The Tyranny Of Distance" 🌊🚣🌊
My delivery of Essence mk 2, BLC, and ML Power Box are weeks away.
I look forward to learning from your experiences Smile
BeoNut since '75
mjmedlo
Posts 922
mjmedlo replied on Wed, Aug 12 2015 1:23 AM
elephant:
I look forward to learning from your experiences BeoNut since '75
So far so good
Set up is totally different.
Many more options with the new BeoMusic app
Deezer, tune in and spotify built in
Join rotates all sources playing.
Shows up in the app to join.
So far so good.
I am using the line in for a 3d party panel and there is a delay which I can't solve
Otherwise it's a nice addition so far.
I've bought two.. I'll probably throw my 1st gen a9 on one and then have it as a beolink speaker. A poor mans a9 2d gen.
elephant
AU
Posts 8,219
elephant replied on Wed, Aug 12 2015 3:30 AM
Thanks for the progress update !
BeoNut since '75
elephant
AU
Posts 8,219
I am starting to plan my installation based on the BLC NL/ML installation guide that Chris left in his dropbox.
Although my installation will be simpler than the picture I have picked from that guide, it does has some of those NL, ML, MCL challenges !
What I am reading is that I will (ideally) have to reconfigure my network -- I suspect a triangle of three Appl1 Time Machines is not going to handle the NL/ML environment ...
The B&O guide states:
Setting-up
Network Link
An extra router (Network Link router) is recommended for the Network Link as it needs it's own subnet.
The WAN port on the Network Link router must be connected to a LAN port on the ISP router with a CAT7 cable. This is done to avoid that data traffic meant for the 1st subnet will interfere with data traffic on the 2nd subnet.
The Bang & Olufsen products can be connected to any of the LAN ports on the Network Link router. Each of the four ports on the Network Link router can be extended with a switch recommended by Bang & Olufsen.
Access the Network Link router
In order for the Network Link router to work when connected to the existing network it must be configured with a different address range than the ISP router on the network.
  • Connect a PC to the Network Link router and enter the default IP-address 192.168.1.1 in the address field in the Web browser on the PC.
I would be interested in any planning thoughts - and recommendations of routers and switches (and there I thought they were the same thing - seemingly not):
BeoNut since '75
lano
Posts 161
lano replied on Wed, Aug 12 2015 6:55 AM
mjmedlo:
So far so good
Is Spotify built in meaning you can browse playlists and songs from Spotify within the BeoMusic app? No need to use the Spotify app? If so, that is great news!
Seanie_230
UK
Posts 2,278
Hi there
If you home network is not very busy and you are a general home user a second subnet will not be required.
I think this is overkill to be honest.
My network at home have over 30 client Of which 3 items are NL and it works perfectly.
I suppose this is a revenue generator or to make sure of minimal complaints that B&o cannot support or explain.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
elephant
AU
Posts 8,219
elephant replied on Wed, Aug 12 2015 8:15 AM
Thanks Seanie for that breath of common sense
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
elephant:
Although I always tend to suggest a second network, I think that in most cases Seanie is right.
If your curent network is working well, you probably won't have any problems.
I'd try that out before investing in more infrastructure.
The Installation Guide is for installers and - of course - they will have to take the secure path of building a subnetwork (especially with bigger installations).
After all they will have to stand up for a correct working setup, once they have left the house.
Millemissen
Flensborg, Denmark
Posts 14,680
lano:
mjmedlo:
So far so good
It is Spotify Connect, that is built in.
Meaning, that you can redirect your Spotify stream from another device to the Essence 2nd gen and then let that do the streaming.
Millemissen
Flensborg, Denmark
Posts 14,680
The User Guide for the Essence 2nd generation is now online on the B&O website -> costumer service.
vlohjr1
Posts 553
vlohjr1 replied on Wed, Aug 12 2015 9:19 AM
Millemissen:
It is Spotify Connect , that is built in.
Mm still with multi room function or individual stream?
Millemissen
Flensborg, Denmark
Posts 14,680
Spotify does not allow multiroom streaming
Use Deezer instead.
DGRouge
Posts 36
DGRouge replied on Wed, Aug 12 2015 1:18 PM
MM, are you quite sure multiroom will not work with spotify? A dealer told me (without much confidence, though, and without demonstrating) that Spotify would do multiroom on Beo products with spotify connect (i.e. on A9 MK2 and Essence MK2, but not on Moment).
vlohjr1
Posts 553
vlohjr1 replied on Wed, Aug 12 2015 1:56 PM
DGRouge:
That's my main question
deezer app on the bvs avant 55 and v1 are horrendously slow and unresponsive
wonder if any fellow beoworlders experienced this
spotify connect seemed to be much better
BeoMegaMan
Posts 601
Spotify will not distribute digitally. You can try to trick things using Spotify connect, but it is still not distributing. If you want to distribute Spotify you will need to run an analog line out of something back into the aux in on a BLC, Essence MKII, or aux input of the A9 MKII. Deezer is the only answer to this currently. I have not experienced nor have any end users that I know of experienced any of the sluggish/unresponsiveness you speak of.
Ah, you know... A little B&O here, a little there
Razlaw
Posts 4,345
Razlaw replied on Wed, Aug 12 2015 5:12 PM
Sorry for a dumb question, but I am a little behind on the new products. Is the Essence only for use with stand alone speakers? Or can it be connected to speakers that are connected to a Beovision?
BeoMegaMan
Posts 601
Razlaw:
The MKII is basically a NL active kit that can share sources. It can function in a network and without one.
Razlaw
Posts 4,345
Razlaw replied on Wed, Aug 12 2015 5:51 PM
So with a netlink converter, I could connect to the current MasterLink system?
And then using the Essence remote could turn on just the front speakers connected to a TV?
Is it possible to have an individual Essence controller for each TV in the Masterlink system?
tradingman
Posts 41
Good Morning,
Can anybody explain me, what is the real difference between MK1 and MK2? OK there is Deezer in MK2 and they say multi room. In the manual I can't find anything that I cannot do with my MK1. My MK1 works fine with the new BeoMusic App Smile
Mat
mjmedlo
Posts 922
mjmedlo replied on Thu, Aug 13 2015 11:42 AM
Mk2 can join with the app
Can mark1?
Millemissen
Flensborg, Denmark
Posts 14,680
tradingman:
Good Morning,
Mat
Hi Mat,
if you don't need (or plan to have) more of the newer B&O products, you'll be fine with the A9 1.Generation - then multiroom is not relevant to you.
The A9 2.Generation has an upgraded hardware (streaming/wifi module) - if yours works fine, don't worry.
If you don't care for the support for Bluetooth 4.0 or for the integrated Deezer music service/TuneIN netradio, the 1.Generation A9 will be ok.
If you are used to control your A9 with a Beo4, you would miss that with the 2.Generation...
Millemissen
Flensborg, Denmark
Posts 14,680
mjmedlo:
Can mark1?
No, because it does not support NL/multiroom.
MARKFS
Posts 90
MARKFS replied on Thu, Aug 13 2015 1:46 PM
Just received my MK2 as well.
Spotify is not supported for multiroom streaming.
If you choose 'Join' / 'Lyt med' on the remote, the only thing that happens is that you can see on your TV what song the essence is playing through Spotify connect.
You can use the Beo4 to play the next song, play/pause, but not control the volume.
mjmedlo
Posts 922
mjmedlo replied on Thu, Aug 13 2015 2:06 PM
Millemissen:
Well there's the difference Smile
jans
Belgium
Posts 394
jans replied on Thu, Aug 13 2015 4:47 PM
Is Deezer supporting multi-room streaming?
lonfred
Posts 200
lonfred replied on Thu, Aug 13 2015 5:19 PM
Yes!
MARKFS
Posts 90
MARKFS replied on Thu, Aug 13 2015 6:13 PM
I have a deezer Premium account, but when I open Deezer in the BeoMusic App I can only play 30seconds preview? Does anyone else have the same problem?
MARKFS
Posts 90
mjmedlo
Posts 922
mjmedlo replied on Thu, Aug 13 2015 6:15 PM
MARKFS:
Moment comes with a year free
Are you in the U.S.?
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Aug 13 2015 6:20 PM
I've just opened a Deezer Premium account today and note that I can only register 3 devices for it!  With an Essence, A9 on the way, 2 iPads, a Mac and a PC etc I'm not sure how to handle that now.
Dave.
vlohjr1
Posts 553
vlohjr1 replied on Thu, Aug 13 2015 6:22 PM
Dave Farr:
Dave.
I have 5 registered at least
MARKFS
Posts 90
MARKFS replied on Thu, Aug 13 2015 7:57 PM
I'm not in the U.S, I'm in Europe.
It works fine in the Deezer App, on the TV and on my Mac. But I can't get it to work on the app. Tried to log out, delete the app and so on?
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Aug 13 2015 9:07 PM
You need to re-enter your Deezer credentials to access your music. The 30 second cut off suggests that you are not logged into your Deezer account.
Opman
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Aug 13 2015 9:10 PM
It's three mobile devices. The multi network products don't count in the three mobile devices.
Opman
MARKFS
Posts 90
MARKFS replied on Thu, Aug 13 2015 9:58 PM
I have tried to delete that BeoMusic App and to log in and out of Deezer through the app. Nothing seems to work.
tradingman
Posts 41
mjmedlo:
Can mark1?
Thanks for your answer!
I have to try this weekend. There was a software update I already installed for my mk1. Perhaps my BV11 can join the music playing with the essence.
Is there any official info for the mk1 users - as it seems it isn't only a software upgrade (mk1 to mk2).
Mat
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Aug 14 2015 9:18 AM
Opman:
Opman
Ah, that's OK then.  Thanks for clarifying that.  More informative than Deezer.
Dave.
HC
Oslo, Norway
Posts 76
HC replied on Fri, Aug 14 2015 7:55 PM
Finally received mine as well, in Oslo! Looking forward to setting it up and finally being able to play music on the BL15&16 installed in the bathroom months ago..
Aussie Michael
Melbourne, AU
Posts 3,730
elephant:
Hello from Hakone Japan :-)
Can't wait to hear your impressions, i think this should be be good for your set up and really enhance your existing equipment.
Unrelated question: Is the A9 90 year edition a Mk2?
Page 1 of 2 (66 items) 1 2 Next > | RSS
